Online Now [291]:
Visitors: 290
Today: 103749
Total: 142614076
Forums › The Car › Request a how-to › To remove roof trim
To remove roof trim
Forum IndexRequest a how-to
lozzybaby7
PostPosted: Wed May 30, 2012 1:16 pm Reply with quote Up
I am trying to replace my roof trim as some noobs tried stealing mine and they are ruined. To remove is it only the little clip by the windscreen that I remove or is there anything else?
Also when replacing new one, can I re-use the clips from old one ?
If anyone could help it would be great Smile
laurax
PostPosted: Wed May 30, 2012 1:20 pm Reply with quote Up
I take it you mean the black plastic trim on the roof?
There is another little clip at the other end, open the tailgate & you will see the plastic end cap with the rivet.
New rivets are cheap from any Peugeot / Citroen main dealer ( if you go Citroen you will need to provide the part numbers )
You can use the old clips if there ok.
lozzybaby7
PostPosted: Thu May 31, 2012 11:00 am Reply with quote Up
Thank you Smile
laurax
  Quick Reply
Username:
Message:
Quote the last message
