Latest: Andyblue64
Overall: 17123
Online Now [57]:
Visitors: 56
Today: 13316
Total: 97960661
Forums › The Car › 206 Problems › Fanbelt needs changing or just tighten?
bozmann
PostPosted: Thu May 31, 2012 11:44 am Up
Got a horrible squeeking noise from my 206 when i started her today. Sounds like its the fanbelt. Is it possible to just tighten it or do i need a new one?
Anyone have a "how to" for a 206 gti 99 modell?
Norway Calling!
PostPosted: Thu May 31, 2012 11:50 am Up
Can't tighten it as it has an automatic tensioner. New belt might fix it.
usher
PostPosted: Thu May 31, 2012 11:52 am Up
am i right in saying you may aswell change the tensioner as well
its the aux belt btw
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu May 31, 2012 12:13 pm Up
Squeeking is usually tensioner and/or idler pulley.
