Latest: lio94
Overall: 17181
Online Now [92]:
Visitors: 91
Today: 58289
Total: 141002803
Forums › The Car › Request a how-to › engine mounts
engine mounts
Forum IndexRequest a how-to
paulspug
PostPosted: Thu May 31, 2012 12:29 pm Reply with quote Up
hi
i'm in the middle of replacing the 4 engine mounts (drivers side = 2).
i have already done the gearbox mount(easy), also the lower mount which was removed by my works engineers and pressed in the new one.
However, i am unsure about the drivers side mount. I managed to remove all the pieces so i was left with just the main mount, but could not move it. As i cant see the bottom : can i assume it is just a twist on/off or is there a specific tool for this job?
had a troll around this forum but not yet have i found an answer.- my apologies if i have missed it -
macj
PostPosted: Thu May 31, 2012 12:34 pm Reply with quote Up
big black rubber bit just unscrews..... use a strap type oil filter remover if its stubborn
paulspug
PostPosted: Thu May 31, 2012 12:36 pm Reply with quote Up
Thank you
  Quick Reply
Username:
Message:
Quote the last message
