Latest: Flyin180
Overall: 17116
Online Now [18]:
Visitors: 17
Today: 12205
Total: 94969411
Forums › The Car › 206 Problems › Inlet air temperature sensor
PostPosted: Tue May 29, 2012 3:17 am Up
any idea where it is? and color?
(2.0 HDi X reg)
PostPosted: Thu May 31, 2012 7:15 am Up
no one?
PostPosted: Thu May 31, 2012 3:28 pm Up
You might well find it's part of the MAP/MAF sensor.
If you unscrew it and there is a visible yellow 'bead', you've found it.
Why?
PostPosted: Fri Jun 01, 2012 1:30 am Up
Why?
so it is inside/ part of the MAF sensor?
no wonder why i can't find the parts number on service box...
last week i do a scan the only fault code that shown up is inlet air temperature sensor open circuit.
PostPosted: Fri Jun 01, 2012 1:37 am Up
I would check as I described but after 2001, most 206 have it integral with the MAP or MAF.
Do you get a IAT reading in live-data mode with the diag tool? It might be 'guessed' ofcourse..
PostPosted: Fri Jun 01, 2012 1:39 am Up
it is constantly at 50 degree.
so pretty sure something is wrong....
the MAF reading do change when throttle applied though....
PostPosted: Fri Jun 01, 2012 1:42 am Up
Yes it is an electricaly sepperate thermistor housed in the same sensor casing.
It is perfectly possible for the temp sensor to cockup and the MAF to be completely OK.
PostPosted: Fri Jun 01, 2012 3:17 am Up
i will have a look during the weekend..
doesn't sounds like a cheap fixed though, new MAF sensor aren't too cheap
PostPosted: Fri Jun 01, 2012 3:20 am Up
If you find the exact type number, you can get the OEM from ebay many times for alot cheaper.
Schumi
PostPosted: Fri Jun 01, 2012 3:58 am Up
In 206 GTI 180. Map and IAT integrated in same shell.
2005 206 RC RED
PostPosted: Fri Jun 01, 2012 4:00 am Up
That explain why i can't find it on service box. thanks Laughing Laughing Laughing
