Online Now [1175]:
Visitors: 1175
Today: 189523
Total: 151673679
Forums › The Car › 206 Talk › Fresh Clutch! Gti 180
Forum Index › 206 Talk
Sprotty
PostPosted: Fri Jun 01, 2012 12:01 pm Up
Just had a new clutch and a re-ground flywheel fitted along with a powerflex lower engine mount.
What a huge difference, really loving the car now after 4 months of ownership, was so fed up with the clutch judder.
Life at full throttle...
james180
PostPosted: Fri Jun 01, 2012 12:02 pm Up
Where did you get the engine mount from?
Understeer is a crime.
JamieM
PostPosted: Fri Jun 01, 2012 12:04 pm Up
Sounds good and as above where did you get the engine mount from?
Aegean Blue 206 GTi180
Sprotty
PostPosted: Fri Jun 01, 2012 12:05 pm Up
Larkspeed. PFF50-306 is the part number! It's a 306 lower front engine mount bush with a 70mm diameter used on the 206 gti/gti 180.
JamieM
PostPosted: Fri Jun 01, 2012 12:14 pm Up
Oh yeah just searched the 206 2.0 and 306 both have same part number. Will get one ordered thanks!
Sprotty
PostPosted: Fri Jun 01, 2012 12:18 pm Up
Next to no movement now when you let off the throttle.
JamieM
PostPosted: Fri Jun 01, 2012 12:19 pm Up
Did you buy your clutch from them too?
Sprotty
PostPosted: Fri Jun 01, 2012 12:24 pm Up
No, got a valeo one from a mate who is a manager at an auto factor so did me a good deal at £90!
JamieM
PostPosted: Fri Jun 01, 2012 12:40 pm Up
Bargain!
Sprotty
PostPosted: Fri Jun 01, 2012 1:18 pm Up
Just shows you the mark up!
MrMorris
PostPosted: Fri Jun 01, 2012 3:37 pm Up
what about the gear box? dont ya have to have a new gearbox with a new clutch? or is it new clutch with a new gearbox?
or is it just some silly myth? Smile
i might invest in a new clutch, mines done 95k now and judders abit if i dont put more than 2300-2500 revs to take off.
Big_Rich180
PostPosted: Fri Jun 01, 2012 3:43 pm Up
Cant tell if trolling or serious?
MrMorris
PostPosted: Fri Jun 01, 2012 3:44 pm Up
serious mate. guessing it is just a myth then...
(altho i don't mean you HAVE to change both at same time, just heard that is was advised? or is that if one goes first, then change both?)
i know nothing to do with mechanics.
Big_Rich180
PostPosted: Fri Jun 01, 2012 3:47 pm Up
Sure is pal.
JamieM
PostPosted: Fri Jun 01, 2012 4:02 pm Up
I didn't even hear about this myth! lollol
