Latest: lio94
Overall: 17181
Online Now [87]:
Visitors: 86
Today: 29243
Total: 141171699
Forums › The Car › Request a how-to › How do i remove the door handles
Forum IndexRequest a how-to
seany_brown
PostPosted: Mon Jun 04, 2012 5:18 am Reply with quote Up
how do i remove the outside door handles, as i want to get colour coded ones, but dont know what tools to take to the scrap yard!
Thanks lads
PostPosted: Mon Jun 04, 2012 5:19 am Reply with quote Up
A cordless drill & some suitable drill bits as the handles are held in with rivets.
seany_brown
PostPosted: Mon Jun 04, 2012 5:22 am Reply with quote Up
so i gotta use my rivet gun to put them back in too ? cheers MrBSI
PostPosted: Mon Jun 04, 2012 5:23 am Reply with quote Up
I've bolted mine back on, works as long as you have a large selection of lengths and heads as some I tried didn't allow it to sit fully closed
PostPosted: Mon Jun 04, 2012 5:24 am Reply with quote Up
You have a rivet gun so you might aswell use it Laughing
seany_brown
PostPosted: Mon Jun 04, 2012 5:44 am Reply with quote Up
do you get to them from the inside (take door card off)
PostPosted: Mon Jun 04, 2012 5:54 am Reply with quote Up
Nope, lift the handle up & you should then spot your target for the drill Laughing
PostPosted: Mon Jun 04, 2012 6:48 am Reply with quote Up
Good idea to take the door card off anyway because as you drill the rivets out metal bits fall inside the door and rattle around if you dont get rid of them. Depends how fussy you are. I bolted mine back on, does the same job and its easy to take off if they ever need to come off again.
marc206
PostPosted: Mon Jun 04, 2012 7:19 am Reply with quote Up
colour code the ones you have on at the mo? just newspaper and tape the surrounding area first
  Quick Reply
Username:
Message:
Quote the last message
