Latest: heikkisj
Overall: 17126
Online Now [135]:
Visitors: 134
Today: 18408
Total: 100351371
Forums › The Car › 206 Problems › 1.4 hdi, air leak?
1.4 hdi, air leak?
skinny
PostPosted: Mon Jul 02, 2012 3:10 pm Up
My 1.4 hdi sounds like its got an air leak
on tick over it sounds like a hissing noise or chuffing, sounds like its coming from under the air filter box.
any ideas what it could be?
Pug 206 1.4 Hdi
Pug 206 Gti 138
skinny
PostPosted: Tue Jul 03, 2012 1:08 pm Up
Nobody?
Pug 206 1.4 Hdi
Pug 206 Gti 138
skinny
PostPosted: Thu Jul 05, 2012 1:46 pm Up
anybody?
Pug 206 1.4 Hdi
Pug 206 Gti 138
richpowell91
PostPosted: Thu Jul 05, 2012 2:17 pm Up
Could be the injector seals, also could be an air leak near the egr valve, have heard that is a fairly common problem.
skinny
PostPosted: Thu Jul 05, 2012 2:24 pm Up
finally Smile
thank you
but surely if its the injector seals it will be running rough?
Pug 206 1.4 Hdi
Pug 206 Gti 138
pudgie
PostPosted: Fri Jul 06, 2012 9:33 am Up
take all the covers off the tpo of the engine the leaking injector will be covered in carbon if not start the engine to find out which one it is.
remove the injector avoiding getting dirt down the hole.
there's a copper washer on the bottom of the injector - remove it and hold it over a flame (gas cooker} with a pair of plyers till its cherry red.
this softenes the washer. refit and tighten down. start the engine to make sure its worked then put it all together
my other cars a delica
skinny
PostPosted: Sun Jul 29, 2012 2:10 pm Up
solved
4 new injector seals fitted
Pug 206 1.4 Hdi
Pug 206 Gti 138
