Latest: DanDan17
Overall: 17128
Online Now [62]:
Visitors: 61
Today: 35331
Total: 100510092
Forums › The Car › 206 Problems › Running rough
Running rough
twitch169
PostPosted: Fri Jun 15, 2012 3:14 pm Up
Hi my friend has a 1.4 206 and seems to be running rough i canged air filter plugs oil and then started it up and seem to run and start easy but she went out in it and started to stutter and stall when she comes to a stop so i no its not the plugs could it be coil pack or fuel filter or a vacume pipe? Could i try my 1.6 8v coil on it ? Thank you
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
twitch169
PostPosted: Fri Jun 15, 2012 3:16 pm Up
It was worse before i did mini service
pazza
PostPosted: Fri Jun 15, 2012 3:37 pm Up
hi ive got a 206 gti and had the same problem but it was 1 of the injectors it is possible that yours could be the coil pack as it warms up the breakdown inside the coil pack
paz
NICKST
PostPosted: Sat Jun 16, 2012 12:17 am Up
I take it you used the right plugs NOT Ngk.
twitch169
PostPosted: Sat Jun 16, 2012 2:42 am Up
Dont see why ngk would be a problem ? Still was doing it with old plugs i gota feeling it could be coil pack or injector ?
Dillon
PostPosted: Sat Jun 16, 2012 2:52 am Up
Staff - Dillon
NGK plugs kill Peugeot coil packs, Bosch it!
injectors on number 1 cylinder are common (no.1 gearbox end, the french couldn't get that right either Razz )
twitch169
PostPosted: Sat Jun 16, 2012 3:31 am Up
O im running bosh super plus on my 1.6 but auto factors gave her ngk so i just fitted them might try my coil pack on it then if plug is the same
Dillon
PostPosted: Sat Jun 16, 2012 3:33 am Up
Staff - Dillon
Wouldn't try your coil pack on it will kill yours too Wink change the plugs !!
NICKST
PostPosted: Sat Jun 16, 2012 5:31 am Up
What He Said
Or you will potentially have two Faulty coil packs and still have to change the plugs.
