Online Now [547]:
Visitors: 546
Today: 116156
Total: 105693053
Forums › The Car › 206 Talk › How to change H4 headlight bulb (frosted headlights)
D-Zaak
PostPosted: Fri Jun 15, 2012 7:51 pm Up
Hi All,
I have a 01/02 Pug 206 that I've owned for 2 weeks and need to change the headlamp bulbs. The markings under the bonnet definitely say H4.
All cars I've had in the past required H7 and changing the bulbs are very easy as the wire locking mechanism is one lever your just pull down.
With these frosted lights, the wire lock looks totally different. It has 2 wires instead of ones (they are on either side, holding the bulb in place).
No matter what direction I push or pull, I can't get the wires to come off or unlock the bulb.
How do you do it?
2002 Peugeot 206 XT 1.6L in Silver
gaffa786
PostPosted: Fri Jun 15, 2012 8:31 pm Up
I think you have to twist them anti clockwise Then pull them out. Not sure but thats how i took iut my side lights
iainlovatt
PostPosted: Sat Jun 16, 2012 2:58 am Up
Pull the connection block off from back of light
Then take rubber cap off
then get release the metal retaining clip
then bulbs falls out,
(My Garage)
michaelbishop
PostPosted: Sat Jun 16, 2012 7:29 am Up
What He Said
Good luck trying to squeeze your hand to the back of the unit if it's passenger side! it is a barsteward!
The Journey, The Garage,
MrMorris
PostPosted: Sat Jun 16, 2012 8:21 am Up
same as every other bulb lol.
just look at it till you figure it out, this however usually requires the attention of atleast 3 male homosapiens. a few beers and burgers won't delay the process, but instead will 99.99999% of the time help the male homosapiens to come to a more realistic and truer plan of action. the plan of action is not always correct, but a plan is a plan and we as a nation would have got nowhere over the last 65,000,000 years if no plan, great or bad, had never taken place.
hope this helps mate.
