Posted: Thu Jun 21, 2012 5:24 pm |
Need all the above for the 180! What rubbers are the best for the exhaust it has a janspeed onit what's everyone useing? And are the engine mounts expensive? And can u buy the bushes alone for the tie rods? If that's what there called!
Posted: Thu Jun 21, 2012 11:26 pm |
There was a thread not so long ago about polyflex exhaust mounts I think and were a b*****d to fit but with a hammer and wd40 should go on.
Try this place a HOLE uprated (grpN) mount kit fir a mint price:
www.shop.pug1off.com/p...cts_id/315
Posted: Fri Jun 22, 2012 5:19 am |
those looks like baker engine mounts
Posted: Fri Jun 22, 2012 5:59 am |
just been looking at engine mounts these are half the price of vibra tech
anyone used them before
for the exhaust i used powerflex and they have little movement.
the rod are they drop links
if so there 15quid from pug
Posted: Fri Jun 22, 2012 6:09 am |
vibra tech mounts looks a billion times better that the baker mounts....
Posted: Fri Jun 22, 2012 6:26 am |
lol not al about looks with this type of item tho is it
Posted: Fri Jun 22, 2012 6:45 am |
Seabook wrote: |
those looks like baker engine mounts |
Well spotted,from pug1off they are cheaper than getting them direct from BBM they are just as good if not better than the vibe tech due to the price.
I could ask Matt if he'd do disscount on a group by if you wanted??
Posted: Fri Jun 22, 2012 6:57 am |
Those Pug1off mounts seem to come with rubber buffers too...with the Vibra Technics mounts they don't need the buffers.
Posted: Fri Jun 22, 2012 6:59 am |
nathdavies91 wrote: |
Need all the above for the 180! What rubbers are the best for the exhaust it has a janspeed onit what's everyone useing? And are the engine mounts expensive? And can u buy the bushes alone for the tie rods? If that's what there called! |
Why do you need them all? Something wrong with the originals? Or just want to change things for the sake of it?
With uprated mounts refinement takes a big nose dive. Things start rattling that just didn't make a noise before.
If by tie rods you mean lateral arms on the rear suspension do you really think these do much? Uprating them will make no difference at all.
Posted: Fri Jun 22, 2012 7:10 am |
I'll make a new thread as I've got an offer on them now so just Gunna gauge intrest
Posted: Fri Jun 22, 2012 7:16 am |
im in for a group buy
Posted: Fri Jun 22, 2012 7:28 am |
140779677303 two group n engine mounts used for a few mile, just spotted on ebay, might be worth a bid
Posted: Fri Jun 22, 2012 7:37 am |
rypod206 wrote: |
140779677303 two group n engine mounts used for a few mile, just spotted on ebay, might be worth a bid |
Rather buy new so they are new from the factory.
I've put a thread up if any ones interested.
Posted: Fri Jun 22, 2012 7:42 am |
so would i to be honest, i fitted vibra technics to mine, plus if anything goes wrong with the top mount you can buy just just the top half, ie fast road to track,
Posted: Fri Jun 22, 2012 11:16 am |
Edward wrote: |
Those Pug1off mounts seem to come with rubber buffers too...with the Vibra Technics mounts they don't need the buffers. |
the rubber buffers are for the 306 there the same set for both cars apart from the buffers
