Latest: elelectricistadeMateo
Overall: 17127
Online Now [104]:
Visitors: 103
Today: 6152
Total: 100404371
Forums › The Car › 206 Talk › engine mount, exhaust rubbers and tie rod bushes!
nathdavies91
PostPosted: Thu Jun 21, 2012 5:24 pm Up
Need all the above for the 180! What rubbers are the best for the exhaust it has a janspeed onit what's everyone useing? And are the engine mounts expensive? And can u buy the bushes alone for the tie rods? If that's what there called!
spike_202
PostPosted: Thu Jun 21, 2012 11:26 pm Up
There was a thread not so long ago about polyflex exhaust mounts I think and were a b*****d to fit but with a hammer and wd40 should go on.
Try this place a HOLE uprated (grpN) mount kit fir a mint price:
www.shop.pug1off.com/p...cts_id/315
**spike's project**
TEAM:+200bhp
PostPosted: Fri Jun 22, 2012 5:19 am Up
those looks like baker engine mounts
usher
PostPosted: Fri Jun 22, 2012 5:59 am Up
just been looking at engine mounts these are half the price of vibra tech
anyone used them before
for the exhaust i used powerflex and they have little movement.
the rod are they drop links
if so there 15quid from pug
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Fri Jun 22, 2012 6:09 am Up
vibra tech mounts looks a billion times better that the baker mounts....
usher
PostPosted: Fri Jun 22, 2012 6:26 am Up
lol not al about looks with this type of item tho is it
project thread WIP
garage
FAQ
206 gti firedance
spike_202
PostPosted: Fri Jun 22, 2012 6:45 am Up
Well spotted,from pug1off they are cheaper than getting them direct from BBM Wink they are just as good if not better than the vibe tech due to the price.
I could ask Matt if he'd do disscount on a group by if you wanted??
**spike's project**
TEAM:+200bhp
PostPosted: Fri Jun 22, 2012 6:57 am Up
Those Pug1off mounts seem to come with rubber buffers too...with the Vibra Technics mounts they don't need the buffers.
PostPosted: Fri Jun 22, 2012 6:59 am Up
Why do you need them all? Something wrong with the originals? Or just want to change things for the sake of it?
With uprated mounts refinement takes a big nose dive. Things start rattling that just didn't make a noise before.
If by tie rods you mean lateral arms on the rear suspension do you really think these do much? Uprating them will make no difference at all.
spike_202
PostPosted: Fri Jun 22, 2012 7:10 am Up
I'll make a new thread as I've got an offer on them now so just Gunna gauge intrest
**spike's project**
TEAM:+200bhp
usher
PostPosted: Fri Jun 22, 2012 7:16 am Up
im in for a group buy
project thread WIP
garage
FAQ
206 gti firedance
rypod206
PostPosted: Fri Jun 22, 2012 7:28 am Up
140779677303 two group n engine mounts used for a few mile, just spotted on ebay, might be worth a bid Smile
206 gti 180
spike_202
PostPosted: Fri Jun 22, 2012 7:37 am Up
Rather buy new so they are new from the factory.
I've put a thread up if any ones interested.
**spike's project**
TEAM:+200bhp
rypod206
PostPosted: Fri Jun 22, 2012 7:42 am Up
so would i to be honest, i fitted vibra technics to mine, plus if anything goes wrong with the top mount you can buy just just the top half, ie fast road to track,
206 gti 180
usher
PostPosted: Fri Jun 22, 2012 11:16 am Up
the rubber buffers are for the 306 there the same set for both cars apart from the buffers
project thread WIP
garage
FAQ
206 gti firedance
