Latest: sparrowdclxvi
Overall: 17139
Online Now [551]:
Visitors: 550
Today: 143645
Total: 112955094
Forums › The Car › 206 Problems › Screeing noise and flashing battery light
lenbt
PostPosted: Fri Jun 08, 2012 12:00 pm Up
recently in this wet weather i've started getting an intermittent high pitched screeching from what seems like the power steering pulley and at the same time the battery light flashes.
after spraying the pulley with WD40 it stops for a while.
Are the bearings on the PS prone to going?
or would the aux belt tensioner cause the battery light to flash if the belt wasn't tensioned right?
Any help would be appreciated
its a 99 2.0 HDI by the way
PostPosted: Fri Jun 08, 2012 12:13 pm Up
Sounds like your belt is slipping but I wouldn't put WD40 anywhere near there because
you can make matters worse.
lenbt
PostPosted: Sat Jun 23, 2012 3:09 pm Up
Just to update this, it turned out to be the alternator, replace it and its fine now.
