Posted: Sat Jun 23, 2012 1:05 pm |
Need new tie rods or tie bars whatever there called!!! mine have started knockin on the 180 so need to replace them! or can you just buy bushes for them? anyone know a sight that sells the bushes for them or even uprated bushes or the compleate unit!!!
Posted: Sat Jun 23, 2012 1:12 pm |
Do you mean drop links?
Eurocarparts.....
Local motor factor they will sell them
Posted: Sat Jun 23, 2012 1:19 pm |
Ooops forgot to mention i mean the tie rods on the rear axle!! anyone know how much they cost? and if u can buy uprated bushes for them? or know of anywere online that sells them?
Posted: Sat Jun 23, 2012 1:21 pm |
The lateral bars? That you get on the 180 axle?
Posted: Sat Jun 23, 2012 1:32 pm |
is that what there called?? ive heard them called so many f**kin things haha! i think there the ones yeh! i cant find anything for them!
Posted: Sat Jun 23, 2012 1:56 pm |
This bit?
Yes you can get up rated bushes for them mate,I think powerflex may do them.
I know what you mean I've heard them been called sway bars/lateral bars/Rear tie rods/out riggers.
Posted: Sat Jun 23, 2012 2:14 pm |
Eurocarparts and they are called tie rod end
These fit on the front, after fitting you will need tracking done
Posted: Sat Jun 23, 2012 5:30 pm |
spike_202. You are a ledgend! That's exactly what I ment! Do they make the bushes for both ends yeh?
Posted: Sun Jun 24, 2012 3:36 am |
No problem mate just did a quick search and found these
www.priracing.com/prod...ter-bushes
Bit pricey if you ask me or try these (may NOT be the right ones tho)
www.spoox.co.uk/catalo...3351bcd94a
Or
Go in to your local pug garage give them your number plate go to the rear axle set up and point to the bushes you need on the diagram.... That's what I do usually.
