Latest: Mr-Koekwaus
Overall: 17125
Online Now [306]:
Visitors: 305
Today: 9318
Total: 99394577
Forums › The Car › 206 Problems › Airconditioning not working
Sjoegerd
PostPosted: Sat May 07, 2016 6:13 pm Up
Hi all,
Since I bought my 206, the airconditioning doesn't produce cold air. I already had the system refill but after that it still doesn't produce cold air. I don't hear the pump kick in.
Anyone some ideas? Fuses, relays?
Deano69
PostPosted: Sat May 07, 2016 8:05 pm Up
I`m assuming you have the A/C Switch on and set to cold.....
The `pump` WONT kick in if there is no gas in the system anyway.
Your best bet is to take it to a proper Aircon specialist , they can put some gas in it , make sure the `pump` is coming on and they put a leak tracing dye in it.
9 times out of 10, it has a leak and using their UV torch they will tell you exactly which bit needs replacing
don't bother taking it to `kwik fit up` or similar places....
because they will just gas it up for 50 quid and an hour or two later it will be just warm air
Sjoegerd
PostPosted: Sun May 08, 2016 6:42 am Up
Had it filled at my work (work at a Peugeot dealer) right after that, it still wasn't cold.
Still, thanks for your reply.
gazza82
PostPosted: Tue May 10, 2016 4:47 am Up
Did they pressure test it? If you have a small leak it will loose pressure very quickly.
Hillsy81
PostPosted: Thu Jun 09, 2016 12:44 pm Up
I just had the A/C system on my 2005 180 serviced as well as vacuum and pressure tested - both fine. There was only 20g out of 700g of refrigerant left in the system - hence it wasn't cooling at all.
Now it's been refilled, it seems to work for a short period of time before becoming ineffective again. I'm a bit worried that it has been empty for some time and still being used which may have damaged the compressor.
I've only driven it with the A/C on for 30mins or so, maybe it just needs a bit longer for the oil etc to spread round the system. Some say to even leave it running on hot air to evaporate any condensation in the system but I'm dubious of this...
Any experience of similar problems would be most welcome Smile
