Posted: Mon Jun 25, 2012 5:21 am |
I was removing my air bag and managed to snap all the plugs off the loom can I simply solder the plugs back on??
Posted: Mon Jun 25, 2012 5:23 am |
Depends on if the pins are still in the plugs with wire to solder on to.
Posted: Mon Jun 25, 2012 5:27 am |
Probably not, just replace the spool or coms unit if you have one
| Team Impossible Possible
Posted: Mon Jun 25, 2012 5:38 am |
Ouch, its multiplexed, thats going to be one expensive mistake if it was the drivers airbag you where trying to remove.
Will be a new com2000 unit.
You will struggle to solder the airbag wires back together on a com unit.
Posted: Mon Jun 25, 2012 5:43 am |
Argh it's multiplexed, can I just get a new spool?i don't fancy getting a comms unit
Posted: Mon Jun 25, 2012 5:50 am |
Mephisto wrote: |
Argh it's multiplexed, can I just get a new spool?i don't fancy getting a comms unit |
Nope, spool is part of the com unit.
Posted: Mon Jun 25, 2012 12:05 pm |
Magic, how hard is it to fit a comm unit?
Posted: Mon Jun 25, 2012 12:17 pm |
Mephisto wrote: |
Magic, how hard is it to fit a comm unit? |
Steering wheel removed, take the plastic trim of around the steering column, undo the clamp at the back, unplug the comm then unclip it to remove it.
Posted: Mon Jun 25, 2012 12:20 pm |
Cheers, are comms unit specific to vehicle type? Ie would i need to get one for a 1.4 deisel, or would anyone fit a 52 plate multiplexed car?
Posted: Mon Jun 25, 2012 12:23 pm |
Mephisto wrote: |
Cheers, are comms unit specific to vehicle type? Ie would i need to get one for a 1.4 deisel, or would anyone fit a 52 plate multiplexed car? |
You need one from a 206 for a start, either match up the functions from your old com unit OR look on the back of it as there are id numbers on it.
OR pm me the cars VIN & ill look up the correct part number on Peugeot Service Box.
Posted: Mon Jun 25, 2012 1:02 pm |
cheers,I'll have a look tomorrow
