Latest: dreyfalon
Overall: 17121
Online Now [415]:
Visitors: 414
Today: 43714
Total: 97343780
Forums › The Car › 206 Problems › Sloppy handling
Sloppy handling
swaynie
PostPosted: Mon Jun 25, 2012 9:08 am Up
The car feels very loose like the back end is detached from the car and when I accelerate then lift off the car snakes am I right in thinking the rear bushes would need doing ?
If your offended by my posts call\r\n0800 I dont care Wink
pudgie
PostPosted: Mon Jun 25, 2012 9:12 am Up
try checking the front bottom arm bushes first they make the car do very strange things Exclamation
my other cars a delica
swaynie
PostPosted: Mon Jun 25, 2012 9:41 am Up
Can they be changed or is it a complete arm
Lex206
PostPosted: Mon Jun 25, 2012 10:17 am Up
ruined back axle.
i had the same thing..
like you dont feel confident enough to take a corner at higher speed right?
Megane 225 RS
swaynie
PostPosted: Mon Jun 25, 2012 11:57 am Up
Yrs but its only when I turn right
swaynie
PostPosted: Mon Jun 25, 2012 3:52 pm Up
ive been outside and the rear is solid but there is play in the front osf wheel with my hands at 12 n 6 so this would mean bottom balljoints
PostPosted: Mon Jun 25, 2012 7:54 pm Up
You can't fit just a ball joint it is complete with the arm. Arms are cheapish and a competent DIYer can do it in under 2hrs quite easily. There is a how to here:-
www.206info.co.uk/Foru...46498.html
swaynie
PostPosted: Tue Jun 26, 2012 5:07 am Up
I'll get these replaced ASAP it's like driving jelly lol
PostPosted: Tue Jun 26, 2012 5:25 am Up
you better do that early rather than later
or this might happen Laughing
www.206info.co.uk/Foru...47004.html
swaynie
PostPosted: Tue Jun 26, 2012 5:58 pm Up
I've just ordered some meyle hd bits that should tighten up the front end
PostPosted: Wed Jun 27, 2012 5:01 pm Up
Cheap or expensive; ignore the clunking and squeaking and any ball joint will do this in the end.
I also notice they are relatively new tyres, I bet they were put on because the play in the joint caused the tyres to wear very prematurely. A new wishbone is cheaper than 1 tyre. In fact, if you fit them yourself, a pair of wishbones is cheaper than 1 tyre!
Some won't agree with that but with my discount I can often get QH wishbones (leading and VERY reputable aftermarket manufacturer) for £28 incl. VAT.
If you live near Swindon I might supply and fit for a reasonable fee.
swaynie
PostPosted: Wed Jun 27, 2012 5:05 pm Up
Cheers for the reply but I've just bought some meyle arms and links as there the best of the best and should stiffen up the front end Very Happy
swaynie
PostPosted: Thu Jun 28, 2012 5:02 pm Up
