Latest: DanDan17
Overall: 17128
Online Now [126]:
Visitors: 125
Today: 1413
Total: 100476252
Forums › The Car › 206 Problems › power steering problem
markj
PostPosted: Wed Jun 27, 2012 7:42 am Up
hi i have a problem with my power steering when im idle and turn the wheel the revs go up is this normal if not what could it be and how much roughly ? thanks guys.
also right indicator turning right flickers off then goes left can u tighen the stick up to stop it doing this thanks
supreme clean north easts number 1 cleaning company!
-Dave-
PostPosted: Wed Jun 27, 2012 7:50 am Up
Trade Rating: +36
Indicator issue is a new comms unit and power steering is normal.
Ex 206 Owner.
markj
PostPosted: Wed Jun 27, 2012 8:18 am Up
any ideas on cost of them ?
Razor34
PostPosted: Wed Jun 27, 2012 8:20 am Up
If it is a multiplexed car and it is the Comms unit then I believe you are looking at around the £300+ mark.
Ray
10rachel90
PostPosted: Wed Jun 27, 2012 8:40 am Up
my indicator used to do that, bad on roundabouts when it decides to go onto left and ppl start pullin out on u
VorTechS
PostPosted: Wed Jun 27, 2012 8:47 am Up
Staff - Vortechs
Turning the steering on my car when idle increases the revs ever so slightly too, so this is normal behaviour I suspect.
PostPosted: Wed Jun 27, 2012 11:46 am Up
It changes the mixture slightly to give more torque which is why the revs go slightly up.
It also lasts a few seconds after the steering has stopped moving.
Same with aircon.
PostPosted: Wed Jun 27, 2012 11:58 am Up
Pressure switch on the power steering system tells the engine ecu to raise the idle speed slightly to compensate for the increased demand on the engine as you turn the steering wheel.
markj
PostPosted: Sat Jun 30, 2012 7:19 am Up
ah right power steering problem solved thanks .
indicator i heard there is a way to tighen up as its a bit loose thats why its indicatin left when turning right ?
PostPosted: Sat Jun 30, 2012 7:21 am Up
You need to tell us what year your 206 is first as there are 2 completely different types of stalk set up used on the 206.
markj
PostPosted: Sat Jun 30, 2012 7:40 am Up
oops yes i forgot its 2002 plate 1.1
PostPosted: Sat Jun 30, 2012 9:17 am Up
Will be the com 2000 unit then.
Go get a new or service / exchange unit as it will come with a warranty, 2nd hand / used ones aint really worth a w**k.
Some motor factors do these com units now as a service / exchange part.
Steering wheel has to be removed to replace the com 2000 unit so if your thinking leather / GTI steering wheel upgrade in the future this is the time to do it.
If your REALLY REALLY brave you can take them apart & try to repair it BUT its not for the faint hearted & if you break it your car less until the com unit is replaced as the immobiliser runs through the com unit.
markj
PostPosted: Mon Jul 02, 2012 2:09 pm Up
oh i see, any ideas on the cost of those? thanks
PostPosted: Mon Jul 02, 2012 2:17 pm Up
just under 400 quid
Jack123
PostPosted: Mon Jul 02, 2012 2:22 pm Up
Seabook wrote:
just under 400 quid
Just saw one sell for £20 on eBay, brand new, boxed, nearly bought it myself to sell on Laughing
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
