Posted: Fri Jun 29, 2012 11:41 am |
Trade Rating: +16
Picked this up from a 307 this afternoon, want to use it in the 206 as an extra 12v socket.
Could someone tell me what each cable is for?
I know the green/yellow cable is earth/-v but what is the purple and brown one for?
The brown one is thinner that the others..
Posted: Fri Jun 29, 2012 12:03 pm |
QuArTz wrote: |
I'd expect the purple to be for +12V to the the heater / center contact (as it''s heavier gauge). That and the ground should be all needed for a power outlet.
The brown might be for illumination - is there a bulb in the socket?
Edit:
According to this diagram there' s a bulb in the cig lighter (see object 98)
Looks like the bulb is lit when lighter is pressed in/heating (which explains me never having noticed it) Looks like the third wire connects the bulb to ground (most likely the BSI controlled delayed/dimming ground).
| Silvermetallic 2004 206 RC | |
Posted: Fri Jun 29, 2012 12:17 pm |
Trade Rating: +16
No.. there isnt a bulb in the socket, I suppose the plug is a generic plug for a 12v socket which could have illumination.
cheers for the help.
Posted: Fri Jun 29, 2012 12:26 pm |
Trade Rating: +16
Yeah. I see that..
Nice one, thanks for the diagram
Posted: Fri Jun 29, 2012 1:36 pm |
QuArTz wrote: |
Yeah. I see that..
Nice one, thanks for the diagram |
Ack... must be really tired... That 3rd wire doesn't go to ground, it's a +12V feed (the other end of the bulb is attached to the ground wire).
Posted: Fri Jun 29, 2012 2:40 pm |
From wiring a house plug perspective. Yellow/green is your earth, brown is power and that purple one is negative. Before playing with electrics d/n battery and put a fuse on the positive wire.
Posted: Fri Jun 29, 2012 4:00 pm |
It's French so nothing is logical. Check continuity with a multimeter before making any connections.
Posted: Fri Jun 29, 2012 4:35 pm |
DeadEyePaul wrote: |
From wiring a house plug perspective. Yellow/green is your earth, brown is power and that purple one is negative. Before playing with electrics d/n battery and put a fuse on the positive wire. |
Loooooool, this is for a car not a house. Two totally different systems
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
