Posted: Sat Jun 23, 2012 4:03 am |
Hi everyone, recently I noticed a rattle from the rear end that has got a lot louder over the last few days, it only rattles going over bumps or when I bang on the o/s tire.
I managed to get it on a ramp at work and there is a small amount of play in the arm. Last year I had to get all the bushes and bearing replaced as the wheel was so wobbly it was touching the body.
I took it back to the place who did the work and they found the rattle to be my axle
He's going to strip it down for me next Monday when I'm back from Ireland. I m thinking it's probably a new axle but not sure, when I was driving home last night it was ok but was a little bit twitchy on the motorway.
What do you guys think, new axle? And where is the best place to get one that isn't gonna go bang in two months
Sorry for the essay
Thanks andrew
| You never really learn to swear until you learn to drive | |
Posted: Sat Jun 23, 2012 4:07 am |
Once the original beam is worn, thats it. As the bearing will have already cut into the ends.
Buy a refurb. That way it won't go again in it's lifetime.
Posted: Sat Jun 23, 2012 4:08 am |
Trade Rating: +46
sounds like the tube is worn. new axle, if you can get one in good condition and no play in it..
Posted: Sat Jun 23, 2012 4:20 am |
the there is play in the arm it is too late to fix it by just changing the bearing
Posted: Sat Jun 23, 2012 4:33 am |
Thanks guys, I knew it really but didn't want to admit it! Has anyone got any good recommendations for a refurbed axle?
Posted: Sat Jun 23, 2012 5:23 am |
Posted: Sat Jun 23, 2012 6:30 am |
Ah well, think it might be time to break it for parts i don't think it's worth it as it needs new top mounts at the front too and it's cost me a good bit since I got it almost two years ago. It's done me good as a first car but I think it may be time to go
I'm gonna get the axle stripped down to have a look at it first though because I will really miss it if it has to go
Posted: Sat Jun 23, 2012 4:27 pm |
I've just emailed KrisB who's a recommended specialist on here. He's said he may be able to fix it if the pins haven't pitted. Think I'm gonna book it in for him to have a look. He also recommends IM axle as he's had problems with others if it needs a new axle, thanks for the info though seabrook. Wish me luck on only having to repair it otherwise I'm looking at spending almost £500!
Posted: Sat Jun 23, 2012 4:35 pm |
Just find someone who's breaking the sane car as you and buy the axle they got for £150 tops
Posted: Sat Jun 23, 2012 4:36 pm |
You can buy replacement axle ends.
Posted: Sun Jun 24, 2012 12:56 am |
How olds the axle spike? I don't wanna buy it and have to replace it again in two months!
Posted: Sun Jun 24, 2012 1:55 am |
If the bearing are worn the stub pin will also be worn. It's not really worth putting new bearings on a worn axle. So I'd dig deep and get your existing axle repaired properly.
Posted: Sun Jun 24, 2012 3:16 am |
No I don't have one mate I sad look for one lol.
Posted: Sun Jun 24, 2012 3:34 am |
IM axles are good i had a refurbed axle from there cost about 360 plus my old one in exchange.
Posted: Mon Jun 25, 2012 11:59 am |
But you can buy the end pieces for 50 euros each.
I just got one axle end and 2 bearing sets delivered 115 euros including postage.
