Latest: heikkisj
Overall: 17126
Online Now [49]:
Visitors: 48
Today: 8074
Total: 100270449
Forums › The Car › 206 Problems › Gearbox for a 2002 1.4 HDi Diesel
Nellie
PostPosted: Wed Aug 01, 2012 12:04 pm Up
Hi My mechanic tells me either the gearbox or diff is getting noisy on my 2002 1.4 HDi.
So I have started to look at prices on ebay but there seem to be so many variations can somebody tell me which is the correct one I require?
Some seem to suggest the 1.6 petrol is the same but I am not sure at all.
Any help/advice appreciated
Neil
Neil C
PostPosted: Wed Aug 01, 2012 12:07 pm Up
Find the local gearbox overhaul place & ask for a quote on a service / exchange unit, they aint that expensive & will come with a warranty Wink
PostPosted: Wed Aug 01, 2012 12:16 pm Up
complete gearbox overhaul will be around 200-300
Nellie
PostPosted: Wed Aug 01, 2012 12:33 pm Up
Ok thanks, But I am friends with the owners of my local breakers and they wont knowingly sell me a duff one but they aren't sure which one I require.
Neil
Neil C
adsayer
PostPosted: Wed Aug 01, 2012 1:00 pm Up
Its been a while but I'm pretty sure the 1.4HDi ratios are unique to that engine. The 1st-4th cluster and the 5th gear are split ratios and ratio respectively. I've never seen them on any other MA5 box.
Cars: 03 206 Look 1.4 HDi & 02 206 Style 1.4 HDi
PostPosted: Wed Aug 01, 2012 2:48 pm Up
all diesel box have very long 3th 4th and 5th gear.
you will bust you engine if you put the petrol box in Laughing
you can find your gearbox model number on the casting.
Nellie
PostPosted: Sun Aug 05, 2012 4:02 am Up
Ok People have confirmed what I thought about the petrol gearboves,
Can you give me an idea where the code on the gearbox is?
Neil
Neil C
skinny
PostPosted: Sun Aug 05, 2012 4:07 am Up
ive got a 1.4 hdi box i can sell for £80 if your interested?
pick up only though
good box no noises at all when it was in the car i broke for spares
Pug 206 1.4 Hdi
Pug 206 Gti 138
Nellie
PostPosted: Tue Aug 07, 2012 2:34 am Up
Hi Interested yes, but a long way for me to come from Devon. In my job as a private hire driver I sometimes come your way I will keep you in mind.
The main issue with mine apart from the slight noise which could be a drive shaft or wheel bearing its hard to tell exactly is that it is extremely hard to get into reverse 1st through to 5th no problems
but finding reverse is a game of hit or miss it will eventually go in after several attempts
Many thanks
Neil
Neil C
PostPosted: Tue Aug 07, 2012 8:59 am Up
Learn to drive correctly then, ALL 206 gearboxes are like that Wink
continentalgt
PostPosted: Tue Aug 07, 2012 9:10 am Up
Never had a problem with my 1.4 hdi going into reverse although I've seen several posts where people complain of this problem. Perhaps the gear linkage need replacing/adjustment?
