Latest: Andyblue64
Overall: 17123
Online Now [138]:
Visitors: 137
Today: 69973
Total: 98341533
Forums › The Car › 206 Problems › crankshaft pulley
crankshaft pulley
markysparky71
PostPosted: Sat Jun 30, 2012 9:18 am Up
advice needed to remove crankshaft pulley !! tried leaving in gear with handbrake on still just turning engine and dragging back wheels! is there any way to lock the flywheel to stop engine turning ? have thought of removing starter motor but acess is grim !!thought this would be easy job any ideas? its a 14hi
markysparky71
PostPosted: Sat Jun 30, 2012 9:23 am Up
Impact gun should shift it.
There are other ways BUT I dont feel confident sharing on here as it could lead to serious injury / damage if carried out incorrectly / somethings goes wrong.
skard
PostPosted: Sat Jun 30, 2012 9:51 am Up
as above, wheel off and an impact gun, few seconds later it's ready to come off.
markysparky71
PostPosted: Sat Jun 30, 2012 9:59 am Up
cheers havnt acess to impact gun just plain old extension bar Sad
markysparky71
PostPosted: Sat Jun 30, 2012 10:06 am Up
Hard hat is advisable in case things end up flying through the air Laughing
gazza82
PostPosted: Sat Jun 30, 2012 10:07 am Up
1.4 hdi is that? You can put a bolt through the bellhousing into a hole in the flywheel. It's on the sump side of the gearbox a few inches up. Can't remember the bolt size, might be 10mm, but once you've found it a bit of trial and error should work.
PostPosted: Sat Jun 30, 2012 10:10 am Up
No comment Whistle...
Needs must sometimes Wink
markysparky71
markysparky71
gazza82
PostPosted: Sun Jul 01, 2012 10:20 am Up
I did it with a 24" breaker bar ... and I've posted how to lock the crank at 4:07pm yesterday ...
