Latest: sparrowdclxvi
Overall: 17139
Online Now [191]:
Visitors: 190
Today: 12501
Total: 113084077
Forums › The Car › 206 Problems › Unblock diesel filter?
Boxerman
PostPosted: Sat May 12, 2012 5:37 pm Up
Hi guys,
When I turn my engine on it flags a error of "Unblock Diesel Filter" I've just put some RedEx in my car thinking it might help will it?
If this wont fix it what would happen in the long term?
How much to get it fixed?
Cheers all,
J
Pug 206 1.6 Sport 110 Owner
PostPosted: Sat May 12, 2012 5:51 pm Up
www.206info.co.uk/Foru...t=fap.html
it will never be a cheap fix
Boxerman
PostPosted: Sat May 12, 2012 6:57 pm Up
Dam. I've got a 6 month warrenty worth up to 500 per visit. From the dealer I brought my car from. Should I give them a call tomorrow and tell them about this fault and see what they say? Or would they not cover this?
PostPosted: Sat May 12, 2012 7:34 pm Up
of course you should.
let them deal with it esp. if you just bought the car.
Matt
PostPosted: Sat May 12, 2012 7:59 pm Up
Trade Rating: +32
As said above. Take it straight back. Don't mess with it yourself or you will void any warranty.
adam_w_1
PostPosted: Sun May 13, 2012 2:13 am Up
This has popped up a few times on my car in the past.
A Motorway trip of about 30 miles at a steady 70mph has always helped to unblock mine. It surprises me how the sellers fail to mention how these vehicles aren't suitable for short trips for long periods.
The FAP system in mine will be straight off when the particulate filter needs replaced; that is gutting it and writing it off of the ECU. They're expensive to replace otherwise! Even more than the clutch/DMF assembly!
206 1.6 hdi 110:\r\nStage 1 remap to 140bhp + 220lbft
PostPosted: Sun May 13, 2012 3:22 am Up
A lot of warrantys dont cover diesel particulate filters Laughing
Boxerman
PostPosted: Sun May 13, 2012 3:38 am Up
I sometimes do small trips. But I do 25 miles to work and 25 miles back and have done that since I got te car. Twice. I will ring them and tell you how i got on. Thanks guys!
andyleep
PostPosted: Sun May 13, 2012 6:28 am Up
There are several items that can cause faults on the FAP system. If it is just the filter that is blocked, a good clean with the pressure washer CAN sort it
PostPosted: Sun May 13, 2012 8:26 am Up
FAP filter will more than likely be classed as a wear and tear item, like other filters and serviceable items....so probably won't be covered under warranty.
jankopet
PostPosted: Fri Jun 29, 2012 6:27 pm Up
Hello.
I will put my problem in to this topic becouse it is the same.
Three days ago warning "unblock diesel filter" appeared. I went to peugeot dealler and he connect my car to computer. FAP filter is 18% full, everything is normal... He couldnt run regeneration becouse, computer didnt let him do that (and i saw sighn on his computer which said "maximum regenerations are achived"???). I never run any regenerations by my self or anyone else. He said that filter is probably not full enough to run it. He reseted warning but on start up it appaered again.
I bought new car. I have peugeot 206 sw 1,6 hdi fap (y 2005) with 98.000 km.
What to do?
Thank you for your answer(s)
Namaste
Lecktorious
PostPosted: Mon Jul 02, 2012 7:13 am Up
Trade Rating: +59
jankopet wrote:
Hello.
What to do?
Take it out a long drive at a steady 50-60mph and it should regenerate itself. Forced regenerations are used when a fully is badly blocked.
'98 Nile Blue 306 GTi 6
jankopet
PostPosted: Mon Jul 02, 2012 10:57 am Up
Thank you for reply.
What is long drive? 30miles, 50miles,...? Is it matter in which gear i drive at 50-60mph? 4th or 5th?
Thank you.
Namaste
