Latest: lio94
Overall: 17181
Online Now [124]:
Visitors: 123
Today: 132766
Total: 140770713
Forums › The Car › Request a how-to › How to... find a ignition Live Wire under the hood ?
Forum IndexRequest a how-to
tinytoontown
PostPosted: Mon Jul 02, 2012 5:43 am Reply with quote Up
Appologies if this has been answered somewhere already, if it has please direct me to the answer...
I need to connect to a wire (Day time lights) which is made live when the Ignition is switched on...
i have searched the loom on the far right of the engine compartment with no luck.. every wire i Tested was not a live one
not that i have tried all of them, there are far to many to put little holes in Smile
(yes i could link in to the light loom, but this would mean switching the lights on, which i dont want to do)
if you have a pic to help me out i would be grateful
thanks in advance
Tiny, proud owner of a 2000 Peugoet 206 Style 1.1 (X reg) in Bottle Green
DeadEyePaul
PostPosted: Mon Jul 02, 2012 5:48 am Reply with quote Up
"every wire i Tested was not a live one
not that i have tried all of them, there are far to many to put little holes in"
ergh! i wouldnt be suprised if you blew a fuse! or worse, fried your ECU. this is not the way you should go about testing wires....
PostPosted: Mon Jul 02, 2012 5:55 am Reply with quote Up
You would be better of wiring them in to the double relay under the engine ecu.
If you used a relay you could have it so when the headlamps are switched on the DRL's are then switched off.
PostPosted: Mon Jul 02, 2012 6:14 am Reply with quote Up
wire it through the engine bay fuse box.
so live wire from the battery, relay in between and then switch via the fise box (ignition)
sulli
PostPosted: Mon Jul 02, 2012 7:19 am Reply with quote Up
positive of battery with a in-line fuse?
206 VAN SILVER!
www.Sheffield-WebDesigns.co.uk - discount for 206info members!!
www.HealthyCigs.co.uk - discount for 206info members!! quote - 206info
tinytoontown
PostPosted: Mon Jul 02, 2012 7:21 am Reply with quote Up
thanks
I did use a volt meter, and nothing has stoped working
paul_c
PostPosted: Mon Jul 02, 2012 10:49 am Reply with quote Up
Do you still have the receipt for the daytime running lights?
  Quick Reply
Username:
Message:
Quote the last message
