Latest: dreyfalon
Overall: 17121
Online Now [498]:
Visitors: 497
Today: 14458
Total: 97540804
Forums › The Car › 206 Problems › Engine immobiliser fault.
Sprotty
PostPosted: Mon Jul 09, 2012 12:13 pm Up
Done this twice now in the past week. Comes up with engine immobiliser fault, it cranks over but won't start. The first time I left it for 10mins and it started fine. Did it again on my driveway tonight, took the key out and tried it again and all is well. Any ideas what could be causing this?
Gti 180.
Life at full throttle...
PostPosted: Mon Jul 09, 2012 12:14 pm Up
Reboot the BSI unit, if it keeps doing it then Peugeot main dealer & BSI software update.
Try spare key
Test aerial
Sprotty
PostPosted: Mon Jul 09, 2012 12:18 pm Up
It did the same on the spare key last week in Germany. What do you mean by aerial test?
PostPosted: Mon Jul 09, 2012 12:19 pm Up
When it wont start open the drivers door & see if the key in ignition beep sounds Wink
PostPosted: Mon Jul 09, 2012 12:20 pm Up
Borrow a mux aerial, or buy one, to rule out that it's not picking up the signal.
Located around the ignition barrel
Sprotty
Will remember that, what does it mean if it doesn't beep?
PostPosted: Mon Jul 09, 2012 12:23 pm Up
It's not detecting a key
Sprotty
PostPosted: Mon Jul 09, 2012 12:25 pm Up
Mux aerial? Is a bsi soft boot a good starting point?
PostPosted: Mon Jul 09, 2012 12:26 pm Up
Sprotty wrote:
Mux aerial?
Your car is multiplexed so it needs the multiplexed version of the 206 transponder aerial Wink
Sprotty
PostPosted: Mon Jul 09, 2012 12:31 pm Up
What does it look like and where does it live?
PostPosted: Mon Jul 09, 2012 12:33 pm Up
It looks like a big black plastic Polo mint with a cable coming out of it.
Lives around the end of the ignition barrel.
Read.
Sprotty
PostPosted: Mon Jul 09, 2012 12:36 pm Up
Cheers to both of you for the help. Will know where to start now if it happens again.
