Online Now [1020]:
Visitors: 1019
Today: 49178
Total: 150362156
Forums › The Car › 206 Talk › Swapping to crystals.
Forum Index › 206 Talk
Jack123
PostPosted: Thu Jun 28, 2012 12:08 pm Up
Sorry if this is a repeated topic, searched but found nothing.
If i was to swap from Frosted, to Crystals, would i need to do anything other then unplug one and plug in the other (Obviously removing everything)
Or are they a different fitment? I believe I have H5? currently.
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
iainlovatt
PostPosted: Thu Jun 28, 2012 12:52 pm Up
there not a straight swap, you need to put relays and things to make them work, iv never bothered, i just upgraded to morettes!!
(My Garage)
Jack123
PostPosted: Thu Jun 28, 2012 12:55 pm Up
Ah, damn.
I found a cheap pair of as new Crystals for £30, fell in love with them, How much would it be be to sort out relays and such? And are they expensive?
Sad
Wanted List;
Crystal Headlights.
iainlovatt
PostPosted: Thu Jun 28, 2012 1:10 pm Up
you can do it on the cheap. its just a ball ache!!
(My Garage)
gazza82
PostPosted: Thu Jun 28, 2012 1:17 pm Up
It's not too bad apart from getting hold of the headlight plugs ... unless you can get some H4 to H7 converters ...
I got a couple of plugs from guy on ebay who was breaking a 206 ... some Citroen used the same part and I think you can buy them new. You'll need two relays and a long length of cable to connect the live feed to the two relays .. I mounted the relays on the back of the headlight covers. Plus to be safe I put a pair of inline fuses between the battery and the relay feeds. Some instructions mention fitting diodes ... but mine have been working fine for a few years and I've not had any problems. I've got the wiring diagrams printed out somewhere .. if I can find them, I'll try and post them up. they used to be on here until the server was rebuilt!
PostPosted: Thu Jun 28, 2012 1:21 pm Up
I have H4->H7 converters for sale, £20 posted Smile
Matt
PostPosted: Thu Jun 28, 2012 3:29 pm Up
Trade Rating: +32
Depends, you could have the plugs already.
Jack123
PostPosted: Thu Jun 28, 2012 3:38 pm Up
On the very basic L model from 1999? Really? Razz
What do the plugs look like? I'll have a gander tomorrow.
Wanted List;
Crystal Headlights.
Matt
PostPosted: Thu Jun 28, 2012 4:13 pm Up
Trade Rating: +32
Oh lol. I doubt it then. Doesn't hurt to look though. Just have a nosey around the loom for any plugs that are taped up. You might need to remove the headlights to see better.
PostPosted: Thu Jun 28, 2012 4:41 pm Up
It's non plexed so dead simple.
Cut the H4 plug of & fit the grey H7 plug on instead.
Change the headlamp stalk for a double optic spec one
There is NO need for adaptors or relays!
The H7 plugs will be less then £8 from any Peugeot / Citroen main dealer.
Jack123
PostPosted: Thu Jun 28, 2012 4:45 pm Up
Sounds better this way, where can I get the H7 plugs to fit though, and would anything need to be modified at the stalk? Which stalk do you mean by the way, can only find one type Sad
Wanted List;
Crystal Headlights.
PostPosted: Thu Jun 28, 2012 4:49 pm Up
You need a double optic spec stalk from a 206 that had factory fitted crystals.
Go to a Peugeot / Citroen main dealer for the plugs / pins OR cut them of a scrap 206.
Jack123
PostPosted: Fri Jun 29, 2012 2:38 pm Up
How much do you think I could get the stalk for realistically?
Might be getting that H4 to H7 converter so I don't have to cut anything.
Could you post an image of the stalk too? I cant find any differences in the ones I'm seeing apart from front/rear fogs, and the odd one with a horn.
Wanted List;
Crystal Headlights.
PostPosted: Fri Jun 29, 2012 4:11 pm Up
I give up Rolling Eyes
PostPosted: Fri Jun 29, 2012 4:24 pm Up
Right, as lee has given the f*** up
You need to:
- Cut off your H4 (frosted) headlight connectors and solder or crimp on the H7 (crystal) connectors
- Change the LIGHT stalk to one which has crystal headlights from brand new EG a GTI
- Enjoy your H7 lights for the rough price of £20 excluding your lights
