Online Now [284]:
Visitors: 284
Today: 6472
Total: 142389321
Forums › The Car › Request a how-to › GTI engine mount replacement how to?
Forum IndexRequest a how-to
usher
PostPosted: Wed Jul 04, 2012 12:35 pm Reply with quote Up
any one changed them or got any tips, ill be getting a full set, i think the lhs one will be easy enough and the gearbox one just really the lower one im a little worried about, any input will help thanks
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Wed Jul 04, 2012 1:06 pm Reply with quote Up
Driveshaft off and then unbolt for the lower one. Bit of a job, is it def knackered?
usher
PostPosted: Wed Jul 04, 2012 1:11 pm Reply with quote Up
yeah exhaust rattling from side to side on tick over and engine moving excessivley, does the drive shaft need to come out, just last time i was near one i spilled oil everywhere
hope you mean passanger side/gear box side that one came out easy
might need to go shopping for the driveshaft nut socket
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Wed Jul 04, 2012 1:34 pm Reply with quote Up
SO you'll need a bottle of oil or two as well. Chain whip type oil filter tool is needed for the mount under the ECU.
usher
PostPosted: Wed Jul 04, 2012 1:36 pm Reply with quote Up
looks like im off shopping, gb oil to replace, oil filter remover, drive shaft socket whatever that size is think its 32mm
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Wed Jul 04, 2012 2:25 pm Reply with quote Up
Drivers driveshaft has to come out as it passes through the same fixture as the bush. Does the rear need to be pressed in?
usher
PostPosted: Wed Jul 04, 2012 2:46 pm Reply with quote Up
think it does but looking on sinfulldesigns 206 the bush just looks to be bolted through the middle
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Thu Jul 05, 2012 9:30 am Reply with quote Up
just been under the car whilst sorting the exhaust AGAIN i saw the mount in question towards the front under the sump area, think i could get it off without removing the DS but will see
how do you remove the one that you need the chain wip for i thoulgt it was nut top and bottom according to the images of vibra technics mounts
project thread WIP
garage
FAQ
206 gti firedance
BigGreenDave
PostPosted: Thu Jul 05, 2012 10:06 am Reply with quote Up
I also need to change my rear engine mount as my car is shaking like a shitting dog, but i might as well do them all if im going to do one. i just hope i dont need to take off the front bumper.
F**k Scene YAWN
PostPosted: Thu Jul 05, 2012 12:01 pm Reply with quote Up
How do you think you'll get the new bush in though?
As for the top mount, the ECU needs removing, the bracket between engine and mount needed removing and this give access to the rubber mount. It is screwed into the car on a nut attached to the car.
usher
PostPosted: Thu Jul 05, 2012 12:06 pm Reply with quote Up
for the lower one i was going to remove the bracket then maybe walk round the corner to a garage to have them pushed in and out as im sure it will be quicker and easier than trying to hammer the new one in
so for the ecu side you need to unscrew the mount it self, the gear box side does that just unbolt either side and lift out or is it more complecated than that
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu Jul 05, 2012 1:40 pm Reply with quote Up
Gearbox side is easy.
james180
PostPosted: Fri Jul 06, 2012 4:23 am Reply with quote Up
I changed mine for a poly mount without removing the driveshaft. Just cut all the rubber out, saw a line into the metal outer part bend it in a bit and pop it out. Fitting the new one is so simple it doesn't need explaining. I'm in Mexico at the min but can post pics when I get home. Took just over an hour start to finish.
Understeer is a crime.
usher
PostPosted: Fri Jul 06, 2012 4:59 am Reply with quote Up
was yours a power flex one as im sure there in 2parts where as the ones im getting are one unit
project thread WIP
garage
FAQ
206 gti firedance
james180
PostPosted: Fri Jul 06, 2012 7:21 am Reply with quote Up
I removed a standard mount and refitted a power flex mount.
  Quick Reply
Username:
Message:
Quote the last message
