Latest: DanDan17
Overall: 17128
Online Now [75]:
Visitors: 74
Today: 15610
Total: 100576308
Forums › The Car › 206 Talk › GOT A AXLE!
GOT A AXLE!
deebee
PostPosted: Thu Jul 05, 2012 10:48 am Up
HI GUYS!
I finally got a abs axle off a quicksilver its got discs! GET IT!
Right only thing is ive asked this before so can i just swap this on my hdi drum abs? just gotta get a new handbrake cable? Cheers guys Smile
Breaking 2.0 hdi with ps and gti bits
PostPosted: Thu Jul 05, 2012 10:50 am Up
For about the fourth time. Yes.
deebee
PostPosted: Thu Jul 05, 2012 10:53 am Up
I have to make sure tom Smile thanks mate ALOT
marc206
PostPosted: Thu Jul 05, 2012 10:54 am Up
Congrats Razz
anton1989
PostPosted: Thu Jul 05, 2012 12:09 pm Up
Trade Rating: +16
so to get rear disc on the back you just have to swap rear axle and handbrake cable?
PostPosted: Thu Jul 05, 2012 1:42 pm Up
Hydraulic brake pipe routing will be different too - possibly.
skinny
PostPosted: Thu Jul 05, 2012 2:32 pm Up
it depends on the year of axle to the year of car.
i put a X reg gti beam on mine and the pipe routing was slightly different, but all you need is a new set of cables
Pug 206 1.4 Hdi
Pug 206 Gti 138
PostPosted: Thu Jul 05, 2012 3:11 pm Up
The handbrake cables are a different length between drum & disc rear axles.
