Online Now [1203]:
Visitors: 1202
Today: 242743
Total: 151367087
Forums › The Car › Request a how-to › oil sump
oil sump
Peachy4878
PostPosted: Tue Feb 12, 2013 5:13 pm Reply with quote Up
has anyone got a how to on the above, have a gti 180, has a damaged sump but have a replacement sump. mant thanks Very Happy
imjeeves
PostPosted: Tue Feb 12, 2013 8:30 pm Reply with quote Up
Remove the bolts put sealer round and refit bolts. Dosnt even need a how to
PostPosted: Tue Feb 12, 2013 10:08 pm Reply with quote Up
You have the replacement, just use that to work out where the bolts pass through. Simple as really.
Deano
PostPosted: Wed Feb 13, 2013 3:33 am Reply with quote Up
Undo bolts move bottom engine mount back clean mating surfaces re seal with hi temp gasket sealant and refit bolts wait till dry refill with oil check for leaks job done !
Peachy4878
PostPosted: Wed Feb 13, 2013 5:34 pm Reply with quote Up
cheers guys
Peachy4878
PostPosted: Wed Feb 13, 2013 5:36 pm Reply with quote Up
i take it that its worth changing the oil filter whilst down removing the sump??
PostPosted: Thu Feb 14, 2013 2:57 am Reply with quote Up
Wouldn't be a bad idea just in case it's picked up and debris from the old sump.
  Quick Reply
Username:
Message:
Quote the last message
