Latest: sparrowdclxvi
Overall: 17139
Online Now [189]:
Visitors: 188
Today: 28958
Total: 113100366
Forums › The Car › 206 Problems › gear linkages
gear linkages
troy
PostPosted: Fri Jul 06, 2012 11:57 am Up
hey. changing my clutch on my 2.0 hdi as it started slipping yesterday. i have 2 questions:
first of all how the f*** do you get the 3 gear linkages off, im a mechanic and have no idea how to get them off without bending/ wrecking them
also do you have to take the gearbox mounting stud out of the box?
cheers
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
PostPosted: Fri Jul 06, 2012 1:37 pm Up
1) Gear linkages can more easily be prised-off by using a 12 or 13 spanner as a lever, then gently at first
working it at the correct angle followed by a massive yank.
2) I think you just need to undo the stud nut and don't forget to lift the box up to take-up the slack when re-tightening it.
troy
PostPosted: Fri Jul 06, 2012 1:49 pm Up
sweeeet, cheers mate. there a bit tight in there aint they.
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
goldpug206
PostPosted: Sat Jul 07, 2012 7:22 am Up
I know how you feel with these. I need to replace the gear selector input shaft seal but i haven't been able to move the pin/bolt that goes through the shaft and the linkage!
goldie!
PostPosted: Sat Jul 07, 2012 9:16 am Up
If you're talking about the securing pin, hammer and point in the correct direction. That means hitting on the opposite end to where the 4 grooves can be seen on the side of the pin head.
Then use a brand new pin when re-fitting (they are very cheap genuine).
troy
PostPosted: Sat Jul 07, 2012 9:23 am Up
got them off now and the box is out but the input shaft sleeve where the thrust bearing runs on has a massive groove on one side where the bearing has been catching. now we know why the clutch went,.
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
PostPosted: Sat Jul 07, 2012 9:30 am Up
Fit a new one and use a dab of molybdenum grease, on it only.
troy
PostPosted: Sat Jul 07, 2012 9:32 am Up
yeah i know. wonder if you can get them non genuine or if its dealer only
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
PostPosted: Sat Jul 07, 2012 9:35 am Up
Its always worth checking the price on a genuine part from a Peugeot main dealer, plenty of people on here have been shocked to find certain genuine parts are cheaper from the main dealer then going to a motor factor for a non genuine item Wink
PostPosted: Sat Jul 07, 2012 9:38 am Up
+1
and the quality on such items is guaranteed to be excellent.
I think that piece is around 10 GBP IIRC.
goldpug206
PostPosted: Sun Jul 08, 2012 5:53 am Up
I guess mine is super tight then. i have tried to turn with mole grips and hammer the pin out from the correct side. I stopped as i feared i would damage the box internally.
goldie!
