Latest: Mr-Koekwaus
Overall: 17125
Online Now [266]:
Visitors: 265
Today: 111457
Total: 99616602
Forums › The Car › Request a how-to › how to debadge front grill
Forum IndexRequest a how-to
nas123
PostPosted: Wed Jul 11, 2012 3:49 am Reply with quote Up
Hi I am looking to debadge my front grill on my peygeot , I have 2 spare grills and looking to debadge, just wondering what's the best way to debadge the grill and how, also I have Ben told I can fill the hole using body filler and what's the best filler to use. Thanks
206boyracer
PostPosted: Wed Jul 11, 2012 4:00 am Reply with quote Up
I would cut a piece from the other grille and plastic weld it in place of the badge. Failing that some fibreglass behind should hold it. You would then need to filler the gaps and smooth it off.
The bonnet recess would need to be welded up and lightly skimmed with filler. If you just fill it with filler it will crack and drop off. Try a search a few people have debadged their grilles.
206 GTI 138.
nas123
PostPosted: Wed Jul 11, 2012 4:02 am Reply with quote Up
I have heard of welding but how is this done
nas123
PostPosted: Wed Jul 11, 2012 4:05 am Reply with quote Up
Forgot to mention I have looked up debadging grill a lot and not find hardly any information. Also I did try to attempt to fill the hole on grill, did a great job until the sides came aprt from filler, so now I have just knocked out the filler out of the grill and looking to start again
206boyracer
PostPosted: Wed Jul 11, 2012 4:34 am Reply with quote Up
Have you left the badge in place and filled it over? I was thinking you meant to make a grille like this item.mobileweb.ebay.co...8371749453
If you are unsure how to weld you would need to get a bodyshop to do it.
206 GTI 138.
nas123
PostPosted: Wed Jul 11, 2012 4:39 am Reply with quote Up
My grill is standard I have taken the badge of them and that's all, but I want it to look like that, I have been folded that they don't look clever then the ones that have been filled in
206boyracer
PostPosted: Wed Jul 11, 2012 5:06 am Reply with quote Up
If you have two grilles you need to cut a piece from the spare grille that will fit between the two halves where your badge used to be. It then needs plastic welding together. I think this can be done using a soldering iron. It basically means you need to melt it together. You will then need to skim over it with a light covering of filler. And sand it back smooth.
206 GTI 138.
craigdmjv
PostPosted: Wed Jul 11, 2012 5:20 am Reply with quote Up
next time im at a scrap yard might try and make on
206boyracer
PostPosted: Wed Jul 11, 2012 5:22 am Reply with quote Up
That's my plan for this weekend too. Lol. Gotta get some bits for my sisters focus so I'm on the lookout for a spare grille for me to play with.
206 GTI 138.
nas123
PostPosted: Wed Jul 11, 2012 5:37 am Reply with quote Up
So if you trying to debadge grill would you make a step by step instruction I can go on from
Nasir123
206boyracer
PostPosted: Wed Jul 11, 2012 6:02 am Reply with quote Up
Ok il make a how to when I do mine. It may take a while to get my grille made and all online tho as I'm busy with work etc. so don't have much time in the evenings.
206 GTI 138.
nas123
PostPosted: Wed Jul 11, 2012 6:05 am Reply with quote Up
Ok thanks for that, would it not just be easy filling the whole with body filler, overlaping it slightly on eachside then smoothing it out
Nasir123
206boyracer
PostPosted: Wed Jul 11, 2012 6:26 am Reply with quote Up
If you fill too big hole with body filler it will just crack. Filler is only for filling minor blemishes and dents.
206 GTI 138.
PostPosted: Wed Jul 11, 2012 7:42 am Reply with quote Up
Don't want much do you?? Just but one, it'll be cheaper than buying all the stuff anyway.
206boyracer
PostPosted: Wed Jul 11, 2012 7:50 am Reply with quote Up
Was thinking of making a how to anyway so it's the kick in the backside i needed. Lol. won't be online for over a month I doubt tho.
206 GTI 138.
  Quick Reply
Username:
Message:
Quote the last message
