Online Now [1156]:
Visitors: 1156
Today: 179440
Total: 151028350
Forums › The Car › Request a how-to › sub wiring help? please
chief93
PostPosted: Fri Jul 13, 2012 7:44 am Reply with quote Up
Just after some advice really. ive got my front and rear speakers powered off an edge amp at the back but i want to also install a sub which will come with an amp fitted already (this one www.ebay.co.uk/itm/FU1...89wt_1185)
but the problem i have is that my head unit only has two outputs as seen in the pictures for rca's. I've already bought an rca splitter to allow both my speakers to be plugged in. what should i do to install the sub? because another output is needed for the sub rca's i thought?
any help is much appreciated thanks!
1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems."
PostPosted: Fri Jul 13, 2012 8:58 am Reply with quote Up
Please keep it to one post for the samething no need for the 4 post you had posted.
iainlovatt
PostPosted: Fri Jul 13, 2012 9:01 am Reply with quote Up
you need some male - femail phono adapters like clicky
(My Garage)
chief93
PostPosted: Fri Jul 13, 2012 10:18 am Reply with quote Up
yh cheers iain ive already bought one of them though to power both my speakers as ive got two sets of rca's to run off only one output. so should i buy another and run a splitter off another splitter? or is there another way?
Cheers
Abzynthe
PostPosted: Fri Jul 13, 2012 10:20 am Reply with quote Up
East Area Rep - Abzynthe
Just get another rca splitter and plug that into the splitter you already have?
chief93
PostPosted: Fri Jul 13, 2012 10:28 am Reply with quote Up
cheers that was the answer i was looking for, just wanted to check it wouldnt affect the sound quality too much?
  Quick Reply
Username:
Message:
Quote the last message
