Latest: heikkisj
Overall: 17126
Online Now [71]:
Visitors: 70
Today: 11252
Total: 100247561
Forums › The Car › Request a how-to › How do I change the crank sensor?
Forum IndexRequest a how-to
very_452001
PostPosted: Fri Jul 06, 2012 3:59 pm Reply with quote Up
Is it a quick job and what tools are quired?
Cheers,
very_452001
PostPosted: Fri Jul 06, 2012 4:05 pm Reply with quote Up
Which car?
Chances are it's just a 10mm bolt holding it onto the gearbox. You'll need to take the battery and box out to access it though.
cartoonhead
PostPosted: Fri Jul 06, 2012 4:10 pm Reply with quote Up
from another post
very_452001 wrote:
ps its a 2006 peugeot 206 1.4 verve
PostPosted: Sun Jul 08, 2012 11:14 am Reply with quote Up
Very very easy. I always did it without taking anything else out on 1.4i.
But why replace it? Do you suspect it has failed?
very_452001
PostPosted: Mon Jul 09, 2012 8:38 am Reply with quote Up
because the garage said it needs to be replaced to resolve the intermittent problem.
very_452001
  Quick Reply
Username:
Message:
Quote the last message
