Latest: DanDan17
Overall: 17128
Online Now [57]:
Visitors: 56
Today: 16441
Total: 100414624
Forums › The Car › 206 Talk › Daft question should be simple answer
Soundinmotion
PostPosted: Fri Jul 13, 2012 9:21 am Up
Silly question but here goes, will renault alloy wheels fit a 206?? Seen a set of turbo rims I fancy if they will fit. But total numpty when it comes to offsets and all that malarky.
Thanks in advance. Mart
I only accept advice from people with big butts.
Because thay cannot lie.
L5_UKS
PostPosted: Fri Jul 13, 2012 9:27 am Up
They wont fit mate
Renault = 4x100
Peugeot = 4x108
evilmunkey87
PostPosted: Fri Jul 13, 2012 9:35 am Up
206 fitment is: PCD 4x108 (distance between bolts) and ET 25 (offset).
If the wheels are 4x108 fitment but have a 38 or 40 offset, you can get spacers and extended bolts to fit, usually about £15 for spacers and £40 for the bolts.
Just make sure you check fitment before you consider buying Smile
Edit*
Just read the first line of your post! Rolling Eyes Renault will not fit whatsoever on to any Peugeot Wink
But still consider the above on any other wheels Smile
206 GTi
Uz
PostPosted: Fri Jul 13, 2012 9:59 am Up
These threads are doing my f*****g head in. I've posted 4 different threads about this now. Look at the top of the wheels and tyres section and all that is a mystery will become unveiled in moments.
PostPosted: Fri Jul 13, 2012 10:12 am Up
Yes it is a simple question
Yes it is a daft question
Yes this has been answered 89 times [you would see this if you used the search function]
If you looked in the correct sub-forum all would be revealed - 206info.co.uk/Forums/v.../f=30.html
[/thread locked]
