Posted: Sat Jul 14, 2012 5:48 am |
Thinking of overhauling cylinder head myself sometime in autum.
Trying to think ahead and prepare a bit, which of the tools available works best with the TU3 setup
because there are many types of valve spring compressors?
Anyone know?
Cheers.
Posted: Sat Jul 14, 2012 1:29 pm |
I don't recommend that you do that by yourself,this kind of work needs a mechanic so that he do it right from the first time,that will cost you less.
Posted: Sat Jul 14, 2012 2:50 pm |
Thanks for advice Timon. I would agree but I'm pretty confident and have all the rest of the tools needed.
I have also relapped valves before a couple of times on smaller engines.
Anyone else?
Posted: Sat Jul 14, 2012 4:58 pm |
V9977 wrote: |
Anyone else? |
www.lasertools.co.uk/i...p;item=123
frd of mine use this to rebuild his 106 XSI
Posted: Sun Jul 15, 2012 2:30 am |
Yes that looks correct for TU3.
Thanks.
Posted: Sun Jul 15, 2012 10:17 am |
A generic valve compressor does the job, there is no actual specific one as far as im aware
And rebuilding a cylinder head aint brain surgery tbh, weekend job if that really
| Team Impossible Possible
