Latest: sparrowdclxvi
Overall: 17139
Online Now [91]:
Visitors: 90
Today: 24686
Total: 113030198
Forums › The Car › 206 Problems › Wiring headlight issue.
jimjam19927
PostPosted: Mon Jul 16, 2012 7:24 am Up
Had a multimeter out and the passenger side dipped beam bulb in my morrettes has dropped to 6v? any ideas why this could be? bulbs work fine its definately the v drop which is causing my issue.
Member: 685
I Over Use Smilies Razz
PostPosted: Mon Jul 16, 2012 8:32 am Up
Poor connection
jimjam19927
PostPosted: Mon Jul 16, 2012 10:34 am Up
Lee wrote:
Poor connection
It was fine then the volts just dropped? Would it be worth removing the headlight and then rewiring and fitting them?
Member: 685
mtempsch
PostPosted: Mon Jul 16, 2012 11:10 am Up
jimjam19927 wrote:
Lee wrote:
Poor connection
How did you get the 6v - probes on the terminals that attach to the bulb?
If you measure between the [supposed] +12V feed and known good ground (like battery pole, as well as between the ground lead in the bulb connector and a known good you might be able to figure out if the problem is on the +12V feed or on the ground side...
You want 12V (~14 w/ engine running) on the feed and as close to 0 as possible on the ground (do the checks w/ light on, as the very low current from a multimeter most likely wouldn't cause much of a voltage drop over a bad connection of itself)
Silvermetallic 2004 206 RC
jimjam19927
PostPosted: Mon Jul 16, 2012 11:59 am Up
mtempsch wrote:
jimjam19927 wrote:
Lee wrote:
Poor connection
Thanks will give this a shot. All the other bulbs are working fine and functions proper like flashing etc.
Member: 685
