Posted: Sun Jul 15, 2012 8:06 am |
Just a quick one! Do these use a gasket for each cover or is it just sealant? One of mine seems to be weeping slightly towards the corner , just want to know so i can grab one tomorrow or just use the sealant i've already got. Thanks in advance!
Posted: Sun Jul 15, 2012 8:52 am |
gasket for each one. would avoid sealant if you stretch to the part - just go careful when fitting and follow the recommended torque settings
Posted: Sun Jul 15, 2012 9:17 am |
SinfulDesignCom wrote: |
gasket for each one. would avoid sealant if you stretch to the part - just go careful when fitting and follow the recommended torque settings |
Cool i thought it would be a gasket just wanted to check. Yeah fitting it is no problem, thanks a lot!
Posted: Sun Jul 15, 2012 10:15 am |
Which cover? As the the 138 uses a simple gasket for the upper and sealer for the lower
Ps forget the torque settings, they are sweet fa anyway
Just make sure you go in an outward spiral
| Team Impossible Possible
Posted: Sun Jul 15, 2012 12:14 pm |
think the gti and 180 are the same
got mine from uni[art for think 12quid each one was labeled for a merc lol
Posted: Sun Jul 15, 2012 4:56 pm |
Addaz wrote: |
Just make sure you go in an outward spiral |
Its the upper one. I've no idea about the 138 but this looks as though it does have some sort of rubber gasket. Will sort one out tomorrow any way and report back!
Posted: Mon Jul 16, 2012 4:39 pm |
Just to update this, got and fitted both today, rubber gaskets as expected. Got both for about £15 quid so all is good now!
Posted: Mon Jul 16, 2012 6:43 pm |
Addaz wrote: |
Right - lets all torque our cam cover gaskets to 50Nm....
