Latest: DanDan17
Overall: 17128
Online Now [66]:
Visitors: 65
Today: 6774
Total: 100526732
Forums › The Car › 206 Problems › Couple of problems...Any help is appreciated :)
SWHdi
PostPosted: Tue Jul 17, 2012 2:17 pm Up
Hey guys
My SW has developed a couple of faults, and i could do with some help sorting them out, first off the speedo doesn't work, it doesn't register miles travelled and the trip/mpg computer doesn't read true, i've had it to a mate of my dads (he has PP) and it's coming back with 3 abs sensors faulty, ( 1 front and both rear) i knew 1 was faulty, could this be the cause of the speedo not working? BTW where's the best place for ABS sensors?? lol
Cheers
Curse you Airbag light!!
PostPosted: Tue Jul 17, 2012 2:55 pm Up
Speedo gets its info from abs sensor. Buy from Peugeot! Check to see if the abs rings on the driveshaft arnt knackered.
PostPosted: Tue Jul 17, 2012 3:27 pm Up
you sure?
i though it get the signal from the speedsensor on the gearbox? Confused
Big_Rich180
PostPosted: Tue Jul 17, 2012 3:28 pm Up
Seabook wrote:
you sure?
Same, when my 180 had all its ABS faults it never effected the speedo.
PostPosted: Tue Jul 17, 2012 3:36 pm Up
ABS, you get signal from rings
Non-ABS you get it from gearbox
But you can also change the settings on a ABS car to get it from the gearbox Wink
Big_Rich180
PostPosted: Tue Jul 17, 2012 3:37 pm Up
So does the 180's signal come from the gear box then?
PostPosted: Tue Jul 17, 2012 3:39 pm Up
Nah shouldn't do.
People sometimes change it to the gearbox when they cba to fix the ABS rings, means the EML won't flick up
Big_Rich180
PostPosted: Tue Jul 17, 2012 3:40 pm Up
Why would mine have worked with the ABS/ESP faults then?
My dad had it from new so no one could have changed it I wouldnt have though.
PostPosted: Tue Jul 17, 2012 3:43 pm Up
Was yours a rear fault or front ABS? Can't remember
Speedo works off the front two, in fact might only be the N/S front
PostPosted: Tue Jul 17, 2012 3:44 pm Up
Doesnt the speedo work of the n/s front BUT the mileage reading come from one of the back sensors.
Im pretty sure it uses 2 sensor to get both bits of info.
Big_Rich180
Had faults on front 2 and rear..front 2 both at the same time and rear was later lol
Who says pugs are bad quality....
PostPosted: Tue Jul 17, 2012 3:49 pm Up
I'll have a look tomorrow if I remember, can't be arsed turning the laptop on and logging in Laughing
Big_Rich180
Fair enough dude lol
SWHdi
PostPosted: Wed Jul 18, 2012 4:23 am Up
Thanks for the replies, I have been underneath and checked gearbox for any sort of connector, only one I can find is on the front of the box, reverse sensor maybe?
Anyway best give the local pug dealer a bell.
Again cheers for the advice.
PostPosted: Wed Jul 18, 2012 5:23 am Up
Check your abs rings first. If one is cracked or missing teeth youve found your problem.
