Latest: Mr-Koekwaus
Overall: 17125
Online Now [168]:
Visitors: 167
Today: 2928
Total: 99362695
Forums › The Car › 206 Problems › Nearside front wheel rocks from side to side. Any ideas?????
Go to page Previous  1, 2
Ash
PostPosted: Sun Jul 22, 2012 5:52 pm Up
Wishbone is a b***h on the 206. Two man job so you can pull the old one out of the hub and put the new one in.
DanT
PostPosted: Mon Jul 23, 2012 1:34 am Up
jam1e wrote:
Thanks folks.
Looks like i'll be ing a wishbone and ball joint.
I'd like to fit it myself as i'm not to bad on the spanners. However, i'm told i'd need a specific tool. Is that the case?
Not sure what this person meant. Could just be a "splitter", which i already have?
Nah you can fit the bottom arm yourself, the ball joint is a bit awkward to do but you're better off using a big lever bar to push the arm down than a ball joint splitter to be honest. Other than that is just your basic french car tools lol. Make sure you've got a big enough socket for the hub nut...on mine its a 34mm not 100% if yours is the same.
jam1e
PostPosted: Mon Jul 23, 2012 5:49 am Up
DanT wrote:
jam1e wrote:
Thanks folks.
Cheers Dan T! Smile
Newbie....
PostPosted: Tue Jul 24, 2012 8:36 am Up
Some are easy some are a b***h. Drivers side is easier than near side due to differences in the drive shafts.
PostPosted: Tue Jul 24, 2012 8:54 am Up
206 wishbones are p**s easy to do Cool
Page 2 of 2
