Latest: Stu-mill
Overall: 17131
Online Now [66]:
Visitors: 65
Today: 16110
Total: 104805531
Forums › The Car › 206 Problems › bleeding brakes
bleeding brakes
REVHEAD
PostPosted: Wed Jul 18, 2012 1:19 pm Up
hi there i need help put new rear brake calipers on at the weekend came to bleeding them up and i cant get a pedal its got alot of travel, i used a one man bleeding system got lots of air out but still no brakes did all 4 brakes but still none help Crying or Very sad
TREV10
DeadEyePaul
PostPosted: Wed Jul 18, 2012 1:57 pm Up
You sure you put the correct caliper on the correct side? I got it wrong and had the same problem. Took to Peugeot and as I didn't know what was wrong and the phoned me up and told me I fitted the L to R and visa versa.
If its not that do you have abs? If so there could be a air lock in the abs unit that can only be bled electronically (Peugeot planet)
PostPosted: Wed Jul 18, 2012 3:05 pm Up
As mentioned, make sure the bleed nipple is on top, there's no kinks in lines. Where are the calipers from? Why have you changed them in the fisrt place?
PostPosted: Wed Jul 18, 2012 3:12 pm Up
Are you sure all the air is out? Get two people on it to do it the normal way I don't trust those systems
PostPosted: Wed Jul 18, 2012 3:50 pm Up
Only an issue if its got ESP fitted.
