Latest: DanDan17
Overall: 17128
Online Now [77]:
Visitors: 76
Today: 17093
Total: 100415275
Forums › The Car › 206 Problems › quick question
quick question
anton1989
PostPosted: Tue Aug 07, 2012 12:26 pm Up
Trade Rating: +16
drivers side wing mirror not working
which fues does it come under? had a look in the handbook had no idea and don't want to go pulling fues
also is there even a fuse for each side?
thanks
Squeaker
PostPosted: Tue Aug 07, 2012 12:29 pm Up
If passenger one is working, i wouldn't of thought it would be a fuse issue. I doubt there is individual fuses for each side.
anton1989
PostPosted: Tue Aug 07, 2012 12:36 pm Up
Trade Rating: +16
thought the same, what could it be?
DeadEyePaul
PostPosted: Tue Aug 07, 2012 12:41 pm Up
Could be the motor inside the mirror housing
anton1989
PostPosted: Tue Aug 07, 2012 2:37 pm Up
Trade Rating: +16
tried 3 different mirrors, the one that is on there, the p/s and one of my old 206
PostPosted: Tue Aug 07, 2012 2:54 pm Up
So many things that could be wrong, with so little information. Most mirrors you look into and you can see behind you so they work perfectly unless the glass is missing.
Plexed? Pre-plexed? Folding? Mirror adjustment? Heating element?
Check the door loom connections to make sure there aren't any loose wires. Ideally you could do with checking the connections for the mirror with a multimeter to see if power is getting to them. Could even be a dodgy switch.
PostPosted: Tue Aug 07, 2012 2:57 pm Up
Switch or door loom
anton1989
PostPosted: Tue Aug 07, 2012 3:04 pm Up
Trade Rating: +16
sorry for the little info i was outside trying different mirrors
car is plexed (52 plate hdi)
normal electric mirriors (heated)
the drives side does nothing and the other side works fine
all i have done is swap switches for the 180 1 as i was goung to fit them, the it stopped working? i swapped back still no good?
what could of happend to my door loom lee?
PostPosted: Tue Aug 07, 2012 3:19 pm Up
Fried some wiring then by the sounds of it.
anton1989
PostPosted: Wed Aug 08, 2012 10:36 am Up
Trade Rating: +16
do i need to replace the door loom? im guessing non plex wont fit a plexed?
just asking as i have one here
