Posted: Thu Oct 11, 2012 10:54 am |
If I didn't fill my tank to the brim does the adblue fluid not get put through?
Posted: Thu Oct 11, 2012 11:06 am |
I have no idea what your on about but I was told you should never over fill a diesel car?
Posted: Thu Oct 11, 2012 11:49 am |
If the adblue is in a different tank it will be fine.
Posted: Thu Oct 11, 2012 12:31 pm |
Sorry, I read somewhere on here that you should always fill your tank to the brim when the fuel light is on - does this affect the regen fluid being put through the system?
Posted: Thu Oct 11, 2012 1:03 pm |
spike_202 wrote: |
I have no idea what your on about but I was told you should never over fill a diesel car? |
If you over fill the tank it just overflows like any other car.
Posted: Thu Oct 11, 2012 1:22 pm |
spike_202 wrote: |
That warnings for the ENGINE oil
Diesel's can run away on there own oil & destroy themselves
If a diesel picks up on its own oil then this happens
www.youtube.com/watch?v=Fw2r_lIRgpY
Only ways to stop them is stall it, CO extinguisher squirted up the air intake, block the air intake OR wait for the engine to explode
Posted: Thu Oct 11, 2012 1:53 pm |
Trade Rating: +59
206HdiGti wrote: |
Sorry, I read somewhere on here that you should always fill your tank to the brim when the fuel light is on - does this affect the regen fluid being put through the system? |
Cerine is injected based on how much diesel you put into the tank. Doesn't matter whether its £10 or £50.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Thu Oct 11, 2012 3:40 pm |
This is getting confusing!! Have you a seperate tank for the adblue? If so that works independently from your main fuel tank.
