Latest: tbafonso
Overall: 17130
Online Now [224]:
Visitors: 223
Today: 2505
Total: 104638855
Forums › The Car › 206 Talk › Fuel pump relay
Fuel pump relay
chilly
PostPosted: Thu Jul 26, 2012 3:46 am Up
Hi wonder if you can help me, im buying a gti 138 on a 51 reg for £300. There is running issues with it. Ive been told its the fuel pump relay. Wheres that located please.
Cheers.
Jack123
PostPosted: Thu Jul 26, 2012 3:47 am Up
For £300 there must be a lot more wrong with it then just that.
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
chilly
PostPosted: Thu Jul 26, 2012 3:51 am Up
Ive sort of told him thats all its worth lol. Its tatty and keeps cutting out. He thinks £300 is fine. Lol
Rob2859
PostPosted: Thu Jul 26, 2012 6:42 am Up
Can't go wrong for £300 to be fair.
PostPosted: Thu Jul 26, 2012 9:29 am Up
Cheers.
Pretty sure its part of the double relay unit which you will find under the engine ecu.
PostPosted: Thu Jul 26, 2012 1:11 pm Up
Yes it is.
chilly
PostPosted: Fri Jul 27, 2012 4:09 am Up
Thanks lads.
chuckstar34
PostPosted: Fri Jul 27, 2012 6:26 am Up
Chilly! Why are you fixing the problem if your swapping bits off it?? Id get it running and use it if you got it that cheap. Or turn it into a good track car!
Chuckster.
