Posted: Thu Jul 26, 2012 5:49 am |
So bassically on my 1.4 206 I have 2 annoying rattles, the first coming from the drivers side, right at the front but it only does it when driving slowly over things like manhole covers etc. second rattle/squeak seems to be coming from the spare wheel cage, when the wheel isn't in the cage it's fine but when it is there is a constant annoying squeak! Are there Anyways of stopping it?without having to remove the wheel from the car alltogether
Cheers
Posted: Thu Jul 26, 2012 5:52 am |
Welcome to Peugeot ownership, there will be many more rattles and squeeks on their way.
Posted: Thu Jul 26, 2012 6:35 am |
Big_Rich180 wrote: |
Welcome to Peugeot ownership, there will be many more rattles and squeeks on their way. |
Beat me to it
The first is probably a suspension component like a drop link. the second, try tighten the cage up or find something to pad it. I took mine out because it always rattled, worse still it didn't matter how much I tightened it, it had a habit of deploying my spare wheel in the middle of the road when I went over speed bumps.
Posted: Thu Jul 26, 2012 6:36 am |
with the front rattle, could be you drop links rattling (tipical 206) or a brake pads rattling in the calipers.
as you your spare wheel situation...dab a bit of grease where the wheel goes up touching the car or tighten the carrier up more with the wheel in...
Posted: Thu Jul 26, 2012 7:29 am |
