Latest: tbafonso
Overall: 17130
Online Now [239]:
Visitors: 238
Today: 2914
Total: 104639264
Forums › The Car › 206 Problems › fan relays??
fan relays??
TCW206
PostPosted: Fri Jul 27, 2012 2:14 am Up
hiya, does anyone have the part numbers for the fan relays on a 2002 1.1??
i tryed ecp and they only have them for cars without A/C??
i assume my best bet is the dealers??
thanks guys
1.1 more door
PostPosted: Fri Jul 27, 2012 5:10 am Up
They are just standard relays available from an accessory shop.
TCW206
PostPosted: Fri Jul 27, 2012 5:32 am Up
ok cool. im a idoit they are the bits that plug into the fan yer?
1.1 more door
anton1989
PostPosted: Fri Jul 27, 2012 5:56 am Up
Trade Rating: +16
If you do a search you will find your answer Wink
TCW206
PostPosted: Fri Jul 27, 2012 6:06 am Up
i did search but it keeps hittin on fan and brings up a shed load of project pages lol or its for the gti... Confused
do u know the answer oow wise one lmfao
1.1 more door
anton1989
PostPosted: Fri Jul 27, 2012 1:59 pm Up
Trade Rating: +16
lol y thank you, was only pulling your leg anyway
this is a 1.4 cant see them being anywhere else on a 1.1, you have to take of your grill, not hard, its 2 torx and 4 mushroom clips hen pull each side off, may nrrd new clips as they break sometimes.
hope this helps,
