Forums › The Car › 206 Problems › gti180 rear knocking noise |
Posted: Fri Aug 03, 2012 7:20 am |
over recent weeks there's been a twanging/knocking noise coming from the back of my 180, we've had it all apart and back together, nothings loose...
Can't work it out and its doing my tits in.
Posted: Fri Aug 03, 2012 7:57 am |
Boot lid? Rear axle? Spare wheel cage? (if it has one)
Posted: Fri Aug 03, 2012 8:17 am |
A metallic twanging noise can often be the anti roll bar bolts being loose or the end plates need hammering on a mm or two more.
Posted: Fri Aug 03, 2012 8:58 am |
My 137 has the same problem, been to 4 different garages and still cant get to the bottom of it!
