Latest: elelectricistadeMateo
Overall: 17127
Online Now [68]:
Visitors: 67
Today: 7553
Total: 100405768
Forums › The Car › 206 Talk › 206 stripping
206 stripping
Neil206
PostPosted: Mon Jul 30, 2012 6:32 am Up
now finally have the car mechanically sound, albeit needing a new cat, i want to get into remiving the interior, just a few questions
- will removing the carpets make the rubber door seals less bulky and therefore let water in, as the carpet is underneath the seals? - as in most cars
- removing the front seats - obviously the XSi has both front airbags, will removing the seats cause these togo off / throw up a warning light on the dash, ultimately the car will have 2 buckets and harness (or pass retains normal seat & 3 point belt and driver has bucket / harness setup), or is there a pin to prevent the airbag going off, like on a corsa b (for those that have owned)?
any help would be appreciated and any extra advice / warnings to please
cheers in advance
206
Neil206
PostPosted: Mon Jul 30, 2012 6:46 am Up
also, sound deadening, what did peugoet use? vauxhall used a combo of that tar stuff roleld downa nd painted over and a sponge layer (inch or two thick)
206
PostPosted: Mon Jul 30, 2012 6:50 am Up
- no
- no
i doubt oem peugeot has sound deadening done
shell-vt
PostPosted: Mon Jul 30, 2012 6:52 am Up
Trade Rating: +46
first off what will you be useing car for..
door seals will be ok
disconect battery before you remove seats(others will give better advice on this)
sound deadening, just lifts out
what type of harness support are you going to use//
york 16,3
PostPosted: Mon Jul 30, 2012 8:21 am Up
Before removing any airbag connections, disconect battery and switch sidelights on and leave for 30 seconds to a minuite to ensure any charge built up is drained.
anton1989
PostPosted: Mon Jul 30, 2012 10:38 am Up
Trade Rating: +16
if your car has airbags in the seats and you remove the seats and replace them with bucket seats which do NOT have airbags, yes you will get airbag faults, not only will that be an M.O.T fail but your airbags will not work if you ever crashed.
PostPosted: Mon Jul 30, 2012 10:48 am Up
Swop the airbag ecu under front ashtray for one from a non plexed 206 with just driver / passenger front airbags & seatbelt pretensioners fitted.
You can then remove the 2 side airbag ecu's bolted to the inner sills.
PostPosted: Mon Jul 30, 2012 11:34 am Up
I will just point out you can remove the airbag with the battery connected as ive seen in multiple main stealers Shocked
PostPosted: Mon Jul 30, 2012 11:43 am Up
Ive done it a few times over the years, ignition off but battery still connected.
If you want a fun one, BMW & reconnect the battery with the ignition switched on Whistle...
anton1989
PostPosted: Mon Jul 30, 2012 12:51 pm Up
Trade Rating: +16
what happens Question
Ash
PostPosted: Mon Jul 30, 2012 12:59 pm Up
I'm assuming they blow.
Why the hell would you connect the battery with the ignition on anyway.
PostPosted: Mon Jul 30, 2012 1:00 pm Up
People that work in garages sometimes make mistakes & it fired the whole srs system of Laughing
PostPosted: Mon Jul 30, 2012 5:59 pm Up
Ouch, expensive insurance bill for the garage then.
Nick_C
PostPosted: Sun Aug 05, 2012 10:07 pm Up
Just stripped out my gti at weekend and was amazed at the amount of sound deadening! Door seals are all fine.
Nick
Nick
Peugeot 206 GTI 180
Currently breaking a 2001 206 GTI - please contact for details/parts
Neil206
PostPosted: Mon Aug 06, 2012 6:54 am Up
yea all gd so far, little water trickling in, traced to a broken r.numberplate light holder / casing
206
