Posted: Sun Jul 29, 2012 5:55 am |
Just been on a drive out to a motor museum near warwick as i came of the M40 i smelled fuel when i got to the car park i opened the bonnet and took the cover off and had pools of diesel around the injectors.
Now i use the car daily and haven't had the leak before but only go 30mph, But on motorway i was doing 70mph for about 30-35mins on the motorway and get the leak.
From what i can see all pipes and clips are on and tight.
Posted: Sun Jul 29, 2012 6:23 am |
Put a picture on mate of the diesel round the injectors
Posted: Sun Jul 29, 2012 6:26 am |
That's quite a bad leak tbh, I'd take it to the garage tomorrow if I were you
Posted: Sun Jul 29, 2012 6:35 am |
only 1 pic works
get a pic of each injector
Posted: Sun Jul 29, 2012 6:36 am |
It's the same on each injector mate all the way across the block.
Posted: Sun Jul 29, 2012 6:45 am |
the fuel return pipe on the left is wet and the one on the right is still dry
Posted: Sun Jul 29, 2012 6:52 am |
cartoonhead wrote: |
the fuel return pipe on the left is wet and the one on the right is still dry  |
thinking it's the injector that end maybe but all the pipes & clips are on and tight.
Posted: Sun Jul 29, 2012 7:07 am |
wont matter how tight things are if one of the seals have gone
get a pic of the other 2 injectors
Posted: Sun Jul 29, 2012 11:24 am |
Took some better pics
Injector 1 (drivers side to passenger side)
Injector 2
Injector 3
Injector 4
Posted: Sun Jul 29, 2012 11:48 am |
jk206 wrote: |
That's quite a bad leak tbh, I'd take it to the garage tomorrow if I were you |
Agreed
Posted: Tue Jul 31, 2012 10:19 am |
Quick update after an hour investigating this morning with a work mate (were both mechanics although he's more skilled on the fuel side working on injectors were we work) we've found a glow plug (in line with 3rd injector from drivers side) was loose and fuel was coming through.
So after trying to tighten it and failing i'm getting a new one and hopefully that should stop my fuel leak.
