Latest: tbafonso
Overall: 17130
Online Now [222]:
Visitors: 221
Today: 38541
Total: 104620292
Forums › The Car › 206 Talk › having snags!!!12
having snags!!!12
andyprice86
PostPosted: Sat Aug 04, 2012 3:01 pm Up
ok sorry if i revive any old posts but i have tried searching the forum google and the 206 handbook but can find nothing!!!!!
right car is a 2004 GTI 180 and i cant find the fuse for the right front and rear sidelights andf also numberplate lightsI have put new bulbs in and none of them work but i just can find a diagram n its doin me nut in!!!many thanks for help
dont be first be last
cartoonhead
PostPosted: Sat Aug 04, 2012 3:04 pm Up
TRY HERE
only knew where it was because macca posted it in another thread earlyer.
PostPosted: Sat Aug 04, 2012 3:18 pm Up
cartoonhead wrote:
TRY HERE
That's the pre plex list. Here is the plexed list
andyprice86
PostPosted: Sun Aug 05, 2012 2:22 am Up
Hi thanks for the lists but that's same as what you get in the owners manual and doesn't say where the sidelight and number plate fuse is thanks tho
skinny
PostPosted: Sun Aug 05, 2012 4:22 am Up
then remove all the fuses one at a time and check for a blown one
if you find one replace it with a new one and touch wood it should be fixed
Pug 206 1.4 Hdi
Pug 206 Gti 138
ukskater01
PostPosted: Sun Aug 05, 2012 5:53 am Up
Do not remove fuses one by one, use a multi meter or circuit tester as fuses may look good but can have hairline cracks in them so they don't work
andyprice86
PostPosted: Sun Aug 05, 2012 4:03 pm Up
Yup that was me next plan. It sure I read somewhere I can't jus pull fuses on a plex car as it will screw bsi up any one know if this is true?
PostPosted: Sun Aug 05, 2012 4:06 pm Up
Yes.
andyprice86
PostPosted: Mon Aug 06, 2012 12:49 am Up
So how do I find the blown fuse for sidelights and number plates
DeadEyePaul
PostPosted: Mon Aug 06, 2012 1:33 am Up
Perserverence that's how!
PostPosted: Mon Aug 06, 2012 2:01 am Up
andyprice86
PostPosted: Mon Aug 06, 2012 3:03 am Up
Awesome thanks so much will get down to it later when I finished work thanks so much
