Latest: Andyblue64
Overall: 17123
Online Now [52]:
Visitors: 51
Today: 41230
Total: 98312824
Forums › The Car › 206 Talk › foglight cold air feed
Neil206
PostPosted: Sat Aug 04, 2012 11:56 pm Up
can someone explain what the 206 airbox is like
currently have a kn panel filter and want to make a cold air feed out of pass fog light, but the airbox disappears down into the front arch and then over the passanger wing etc
isit a gd idea or will i upset a load of electronics etc if i use ducting to take air from foglight to the bottom of the actual panel filter airbox?
206
PostPosted: Sun Aug 05, 2012 12:32 am Up
Neil206 wrote:
isit a gd idea
Well worth the effort for the hundreds of horse power you'll un leash....
PostPosted: Sun Aug 05, 2012 1:30 am Up
As you haven't provided enough information. No idea.
DeadEyePaul
PostPosted: Sun Aug 05, 2012 1:36 am Up
Down there seems like a good idea to put a air duct but your might end up with water damage from sucking up water.
Morettes seem like a better idea. Remove one of the high beam lense and put a air duct there
PostPosted: Sun Aug 05, 2012 3:53 am Up
so as the oem desgin
Ash
PostPosted: Sun Aug 05, 2012 9:39 am Up
You can do it with ease if you find the end of the airbox. The arch covers don't take long to take off so pull them off and have a look.
But as said, you're likely to suck up water, especially with the weather we are having and therefore, it will be fuckkked.
PS. It's a 206, it isn't going to go much faster.
Neil206
PostPosted: Sun Aug 05, 2012 11:46 am Up
ok cheers guys, sorry for any offence caused by the h8rz
206
PostPosted: Sun Aug 05, 2012 4:03 pm Up
Caused by the what???
