Online Now [345]:
Visitors: 344
Today: 127024
Total: 155082614
Forums › The Car › 206 Talk › clutch help
clutch help
Forum Index › 206 Talk
seany_brown
PostPosted: Sun Aug 05, 2012 3:45 am Up
Hi lads, just in the middle of changing the clutch and thrust bearing on a 1.1 engine,
Shafts are out and linkages are off, other than the mounts and gearbox bolts what else holds the gearbox to the engine?
Cheers sean
o050cal0o
PostPosted: Sun Aug 05, 2012 4:44 pm Up
Nothing. Dont forget about the reverse light wire I had to cut mine as it wouldnt come out. Mine is the 180 and there is a gearbox bolt hiding right round the back that may still be in if its still stuck.
Peugeot 206 GTI180
pug206lx
PostPosted: Sun Aug 05, 2012 5:01 pm Up
Starter motor (gearbox bolts go through it). there's a bolt going through the exhaust bracket as well. The crankshaft sensor and piece of plastic will stay on the engine but be careful not to damage it.
It might be stuck on the dowels if you cant get it off.
